Hi all,
I need some cheap eq, bass enhancement etc. for my amp.
The ADAU1701 should fit the requirements and now I would have a question for you. What could sound better:
1. https://pl.aliexpress.com/item/32807805635.html
or
2. https://www.tinysineaudio.com/index.php?route=product/product&path=59_79&product_id=183
Unless there is something better for a comparable amount?
Thank you for your time 🙂
or
Aliexpress MiniBoard:
Pro: Brings out almost all the 1701 signals in case you want to add DACs, etc.
Con: You need to provide all connectors, no mounting holes
TinySine Board:
Pro: Comes with connectors, mountings holes, etc.
IMO has better (larger) caps in audio path
Con: Limited to 2 X 4 configuration, extra 1701 lines not brought out
I have both and prefer the TinySine board for 2 X 4 applications.
TinySine Board:
