Cheap and decent 12” coax
Yeah that one looks pretty nice too. Only measurements will show if any of them is better than the other. By better I mean mainly the woofer response in the 1-4khz region, which seems to be bumpy ride for most drivers and hard to pull of passive crossover. Actually sica 10cx looks a bit better in passive crossover perspective if figuring out the crossover frequency by driver size (match polar response at crossover region), which would be around 1.5kHz for the 10". I'm not sure how coaxial speakers measure in this regard and if it is of any importance. Sica datasheet says nominal dispersion is 100 degrees, not sure at what frequency that is so cannot say about the crossover much before measurements. Peterbrorson, it would be cool to see measurements of the Sica driver when you get it 🙂
while we are at it, what do you think of the p.audio sn6-150cx, another 6.5" pa coax
looks to be used in the trenner & friedl osiris
Product - Pro Audio Components
