CFH7 Amp
If the Inductor is moved off the PCB and put into the cable running to the speaker terminals, then lots of space left over to fit the terminals in between the big decoupling capacitors. Then some rationalisation of the traces can be made to improve the layout slightly.
This should easily get under the 100mm length.
It might be worth looking at moving the feedback tappings and the speaker out away from the strip trace that passes between the source/emitter resistors. At the moment the feedback and the speaker out are on opposite sides of the source resistor trace, (I can see avoidance measures for D.Self's avoidable distortion).
The two 1k0 feedback resistors could be commoned at the left side. Then a single feedback trace could be run passed all the other components.
CFH7
Hello Sonal
greetings trying your pcb layout
warm regards
Andrew😉
Thanks all of you for support and encouragement.
Latest revision, made changes on suggestion from AndrewT.
Board will be cut as shown by outline by pcb manufacturer, also square hole will be cut for BD139. But for those who will diy pcb they have to make rectangular board I'll post pdf of rectangular version.
Hi Sonal ,
is there a need to cut square hole? Can it be done with a oversized round hole, like done in case of Jason's VSSA PCB ?
reg
Prasi
CHF7 in 100mm X 77.5mm.
CHF7 Sprint file has both version 1.06 of layout with inductor and version 1.07 without inductor.
Gerber has only without inductor version.
just looking for defects............
Thiago
A thankless job but great to have someone looking over closely on circuitry we try out. Sometimes errors or plain application looks ok to us even on a double check but it will get caught out by a second person. So it's great that Andrew does this. We need to thank him ! Can raise hackles sometimes with other people but, generally speaking, a good thing ! 🙂 :up:
He could learn to praise too ...
Thiago
Actually many of us think we have done a great job. That should be enough ( self!) praise ! We can see some ego's soaring around here.Surely that should be enough I think. 😀
We don't need it from everybody. If just one person says 'nice' that should be enough as it acknowledges that the ROW appreciates it. But is that really required ?
What matters is if what we made sounds very good. That's should be sufficient I guess !
And we have all heard that " Pride goes before a fall " . So limited amounts of positive acknowledgement should be enough ! 😀
