ceramic capacitors ....
how good are ceramic capacitors ???
what is the range of application ???
we often hear that ceramics for input filters ,miller caps, feedback traces are better to be mkt or styroflex or silver mika ....( eventhough ceramics exist in comercial application )
then if its a low fi application like small psu with 7812 or 7805 is it ok to use there as decoupling or over the rectifier ????
thanks
there are two downsides to ceramic that I'm aware of.
1.) capacitance varies with applied voltage.
2.) Non NPO/C0G vary capacitance and other parameters with temperature. NPO/C0G vary their other characteristics just like the hiK versions with temperature.
If you keep the voltage constant (eg. supply decoupling) most of the disadvantages of 1.) are avoided.
Some designers swear by ceramics for local or on pin decoupling. Even to the extent of recommending the high K specifically for this use.
I think everyone is agreed that ceramics are not good at passing Audio Signals.
Few, if any, other capacitor types can challenge the low inductance of ceramic. If low inductance dominates your requirement, then possibly ceramic might be your only solution.
Ceramic capacitors can be useful. They are fine for supply bypassing, especially the SMT types which have very low inductance. You must consider what the actual capacitance will be at the voltage you use them at - look at the datasheet.
You might find it interesting to look at Cyril Bateman's article on capacitor distortion, which you can find on his website. It shows that C0G ceramic capacitors have very low distortion, while other types are very bad and thus should not be used in the audio path if you're at all concerned with sound quality.
Hi Saki
It is true that some types (e.g. CD15 +/-1% series of Cornell Dubilier for 1,26 GBP/piece excluding VAT) of silvered mica caps offers great stabillity under any condition. This is usefull in timing circuits or other close tollerance applications like in filters included of course the Miller pole compensation etc.
Nothing more, nothing less. I have used them in my last amplifier project and i had a small improvement (it is very difficult to hear) in high frequencies. OTOH i had a great visual improvement on my project PCBs appearance 😀 😀 😀
All above mentioned by Andrew, i think are very explanatory.
Fotis
Quoting from Cyril Bateman:
"‘Ceramic’ covers an extremely wide range of dielectrics. In the seventies the Erie Company produced more than fifty different capacitor ceramic formulations, sub-divided as Class 1 (non-polar) or Class 2 (polar) according to the materials used.
Class 1 ceramics do not contain Barium Titanate, so have a low ‘k’ value. The best known is C0G. With its controlled temperature coefficient of zero ± 30 ppm, it was originally called NP0 by the Erie Corporation. It is non-polar and has a small dielectric absorption coefficient. From my tests it has almost no measurable harmonic distortion. COG ceramic is more stable with time and temperature than mica capacitors and from my tests COG can produce less distortion.
C0G ceramic provides the most stable capacitance value, over long time periods and temperature excursions, of all easily obtained capacitor dielectrics. It is frequently used as a capacitance transfer standard in calibration laboratories. Yet as a small disc capacitor it costs only pennies. Assembled as a multilayer, it can provide capacitances of 100 nF and above, rated for 100 volts working, and much higher voltages for smaller capacitances.
Other Class 1 ceramics, sometimes called ‘low k’, provide increased capacitance within a controlled temperature coefficient, e.g. P100, N750 etc. in ppm. These also are non-polar and exhibit little dielectric absorption. I have tested up to N750, sometimes called U2J, and found very low distortion."
One clear problem with hi-k ceramics is that they are microphonic. While probably all caps have some degree of this, Class II ceramics are particularly afflicted since they are made with barium titanate, a piezoelectric material. Prof. Leach once told me he heard them audibly singing in circuit as lag caps when he was testing an amp. Since Class I ceramics (C0G) are not made out of barium titanate, they should not be as microphonic. However, I have not been able to find any info on just how microphonic or not they are.
From this link (bold mine):
Certain classes of ceramic capacitors exhibit a normal characteristic, called piezoelectricity, than can cause unexpected effects in certain circuits. In some cases, the piezoelectric effect may result in the appearance of electrical noise, while in other cases, an acoustic sound may be heard, coming from the capacitor itself. Ceramic piezo effects are well known, and were even the basis for the ceramic phono cartridges used in the past.
Piezoelectricity is a common characteristic of many ceramic chip capacitors and occurs in those classes of dielectric which are classified as ferroelectric. Piezoelectric effects can result in noise for ferroelectric ceramic chips, such as those used for military BX & BR, as well as commercial EIA Class 2 and Class 3 dielectric, such as X7R, X5R, X8R, Y5V, Y5U, Z5U, etc. Piezoelectricity occurs in all ferroelectric dielectrics, regardless of manufacturer. Note that there are essentially no piezoelectric effects in Class 1 capacitors, such as C0G, NP0, or military BP - none of which are ferroelectric.
...:bigeyes:
tvicol said:
...Take a 10nF NPO, connect to an oscilloscope, switch to highest sensitivity and hit that cap. Tell me if you see something on scope...
Unfortunately the only ceramic capacitors I have which I know are NPO are all really small (<100pF) and thus show no response, but I went through several ceramic capacitors from my unsorted box, some of which are almost certainly NPO, and found:
  • Some ceramic capacitors (presumably the high-k ones) exhibit huge spikes of 50mV or more when tapped hard.
  • Some show only a slight hiccup of maybe a couple of mV.
  • All other types of capacitor I tried (polystyrene, polypropylene, polyester) also showed a small bump of around 1mV.
This makes them all look worse than they will be under normal circumstances though, because 'scope probes are very high impedance, and a high-speed finger nail probably exerts a lot of pressure.
EDIT: I just found some 680pF silver mica capacitors. I must have salvaged them from somewhere because I have never bought any. Anyway, I tapped them and got... about 1mV. I wonder if it isn't the case that the ~1mV that all these capacitors are showing isn't coming from somewhere else, because it seems unlikely that they would all be so similar otherwise.
