CDM1 Laser power adjustment Marantz cd-94 95 99
Please tell me, anyone has a marantz cd-94 95 99, adjust the laser power, measure the voltage of R309...A photo of the location of the circuit board...
Thank you experts...
The laser power is adjusted by playing a test disc (or an average disc) by adjusting the resistor 3180 (or 3140) on the underside of the CDM-1, until the voltage across the resistor R309 is 575 +/- 75 mV. The variable resistor 3180 is 1k, located near the 8-wire flex cable going to the laser head.
You have to remove the bottom plate in order to access the CDM-1 PCB. I place the CD player onto a pile of books on the edges and use a mirror as a help for underside access. TBH I never had to do this adjustment.
R309 is on the green Servo Board seen on your picture.
Bad idea to replace the original capacitors. I see a Roederstein electrolitic capacitor, the gold serie Roederstein capacitor are really bad quality. I don't know why they are well considered in the hifi world, but they are really bad. They use to short circuit, leaks, etc...
Something very confusing happened... The laser power is adjusted by playing a test discby adjusting the resistor 3180 on the underside of the CDM-1
The highest can only reach about 350mv
I don't know what else might be wrong??
