CDM1: help please: removal of spindle motor shaft
I was able to order the teflon screw at a one of the 'big' electronic retail markets in Germany. Cost is about 3.5 Euro.
I will be back in Germany in 4 weeks to pick it up and tell you then if I received the correct part.
joe
Mission DAD7000 (CDM1), don't read CD TOC
before i'm moved to new house in august, i've some problem with read the CD TOC. I spend a lot of time by any disk, because i've eject and insert more times the disk for reading the same.
I've your help to fix this problem.
best regards
Does anybody has an exploded view od the whole CDM1 mechanism?
Need some help.....
I have a California Audio Labs Aria (first generation). It's a Philips based player. Don't know which model. The tray unit is all plastic. I believe it's CDM1. The tray doesn't want to slide out. Does anybody know how to disassemble the tray mechanism? Any help is appreciated. Thanks. Mark. :bawling:
