I was able to order the teflon screw at a one of the 'big' electronic retail markets in Germany. Cost is about 3.5 Euro.
I will be back in Germany in 4 weeks to pick it up and tell you then if I received the correct part.
joe
joe
Good news: The parts I've received are the correct parts. Cost was less than expected, 2.61 Euro a piece. So no need to re-use the old screws any more.
Mission DAD7000 (CDM1), don't read CD TOC
before i'm moved to new house in august, i've some problem with read the CD TOC. I spend a lot of time by any disk, because i've eject and insert more times the disk for reading the same.
I've your help to fix this problem.
best regards
best regards
Does anybody has an exploded view od the whole CDM1 mechanism?
Need some help.....
I have a California Audio Labs Aria (first generation). It's a Philips based player. Don't know which model. The tray unit is all plastic. I believe it's CDM1. The tray doesn't want to slide out. Does anybody know how to disassemble the tray mechanism? Any help is appreciated. Thanks. Mark.
Need some help.....
. I believe it's CDM1. The tray doesn't want to slide out. Does anybody know how to disassemble the tray mechanism? Any help is appreciated. Thanks. Mark.![]()
check out this:
http://www.nanocamp.de/manual/cdm-1.pdf
Its the manual for the cdm1
Looking for Mission DAD7000 part.
Hi, new to this forum. Hope someone can help me out. I am looking for the tray cog assembly for a Mission DAD7000. Hopefully someone has a parts machine lying around. You can reach me at lawaudio@gmail.com Thanks in advance.
