CDM 2/29 Problem – HELP!
A few days ago I was doing some work with my Grundig CD 9000. I found that the four-lead cord from the servo board is quite stiff and that it pulls or pushes the wobbly CDM, so I decided to change it with more soft one. I changed the solid wires with the litzy wires that I took from microphone cable. I got stuck with the little connectors for hours just to find that I have fitted two ends in wrong order. I had no more patience to disassemble all again so I cut the wires and soldered them together in proper order. I checked with DMM all fine.
I fired up the player and it started spinning the disc but doesn’t recognize it.:dead: The laser makes two tries upon startup, up and down, but no lock… Since than I have been searching and reading but found no solution that works for me… I have found service manuals only for similar players but there is no servo or CDM schematic… My player uses the same main board as Philips 640, 650, 660… but CDM 2/29.
I can provide photos of the board/player for someone that has the patience and goodwill to help!
Could it be that new no solid wire makes the problem?
Here is the photo of the servo board (without THE cable)
These plugs are designed for a specific size solid core wire because the action of assembling them cuts through the insulation and makes the contact.
If you have disassembled them and used different wire this could be your problem.
Removing these plugs can also crack the dreadfully cheap circuit board used by Philips because you need to bend down the locking tab for removal. I did this and the crack in the board just happened to be where a track was. Took me a long time to find it.
Hmm,
I think you are talking about the connector type like we see today in computers. These are in fact 20 years old type with separate chambers for each contact and connector feet you can take out.
At least the disk spins and the laser tries to do something when its connected, only it does not read the disk...
Here is the pic of the wire and connector foot taken out:
I have got the manual now, thanks to aparatusonitus so I hope i will be able to do something... I am more and more convinced that I must have done some harm during disassembling of the CDM and servo board, perhaps disturbing some old bad joint.
In previous posts I have forgot to mention that it is the motor power cord that I have changed, +2, -2, ┴, Vc .
Still no result
Only thing I am able to find suspicious is that I don't measure nothing across the 2136, and the manual says I should measure +-400mV adjusting the pot 3146! If I could read Dutch...
aparatusonitus, could you send me the service manual please.
Bassivus, this is the connector I am thinking of. The wire goes in unstripped and the v shaped part of the pin is forced over the wire, cutting through the insulation and making contact.
You can of course check the continuity from socket to socket (cable plugged in obviously) to see if your connections are ok.
I have dealt too with cdm2 a few times, had same errors.
There is also a big (9 wire?) connector for HF signal to SAA7210 , this one can have faults too. (servo pcb to decoder pcb) Best is to repair that cable as the 4 pin, a check with DMM allways proofs nothing, when reassembled the fault re occurs, i had that at least. After 18 years of duty some connectors may oxidise. Or the solid wires can be broken on the ends.
The grey philips connectors can be dismantled, the copper pins have a fork wherein the solid core wire makes contact after pressing the connector parts together.
I have repaired some: First align the wires on both ends with tape. After dismatling of connectors (lift clips) shorten wire 3 mm each end. Press all the tiny forks a little bit smaller with a small flat gripped tool, and reassemble connector, by pressing it carefully in a bench vice. Before that check if all wires are in the correct position in the connector, not too far in or out of it. In special the big connector has to be pressed some to be reassembled. The vice helps to press the parts straight aligned (parallel)
Btw the whole wire assembly with connectors is allways mirror-symmetric. (pin 1 becomes pin 4 in a 4 pin connector) and the connector has a wedge for fitting in the female pcb part, it is pounting outwards
Good luck.
No stoolpigeon,
unfortunately no. I came to conclusion that the new cable does what it is supposed to do, but the player still doesn't read TOC. All the measurements I have checked are fine except earlier mentioned:
But I believe its because the laser doesn't lock in.
tubee said:
What does the cdm do? Check all wires first. If the laser cannot find focus point, the feedback loop from servo is disturbed and nothing happens further. (only some movements of laser focus)
Hello tubee,
I have checked all the wires.
I indeed have found one that must have gone out during disassembly(see attachment). This was the 14 wire "extension" cable - flat laser c. to flat servo c. I was sure that will fix the problem... but nope.:whazzat:
Now some description of the "start sequence":
Immediately on power up disk moves a bit. Its like very little, like max 1 cm measured on outer rim of the disk. After 1/2 to 1 sec. disk spins quite fast and after about 1 sec. you can see second "initiation". Display writes: "disc".
With no disc in the tray you can see the lens going up and down for two times.
Thanks!
Do you see (without disc) a red light in the lens for a moment after pressing start? (Don't look straight in, but sideways!)
Does the laser arm move? Or changes position for a moment, or feels "powered" when you touch it with cdp switched on? If not check + and - 12 voltages on the servo opamp from servo board. Oh yes, you can only check this when a cd is put in (focus must be found) So you have to look under CDM.
Beware: ground yourself on heating tubes or so before touching laserprint connections, the laserdiode assembly is VERY sensitive for ESD! A pity
when a solid radial cdm is destroyed
Bad gnds can also often found too on that players (gnd connections to shield of decoderboard)
Good luck!
