I did a search for the PN of the laser pickup and these links came out:
http://www.diyaudio.com/forums/showthread.php?postid=1752136
http://www.diyaudio.com/forums/showthread.php?threadid=111364
DLBA2Z2001A (original) and KSS152A (possible Sony replacement) are also used alternatively in a lot of Luxman players (D111 - D115)...who knows, it might work afterall!
Re: that was ...
Excellent!!!
I will email you over the weekend when I get a chance to look closely at the thing... even if they are not "high quality" doesn't matter, if it works, and/or I can steal the laser diode!!
Thanks!
_-_-bear
PS. this is the KS 155A, don't know if that defines the pins...
sakis said:actually very easy the kss151 is comonly available in greece after all and was easy to locate by the first phonecall ...it will cost the astronomical figure of 18 euros
two things bother me though one that the prize is actually too low which might mean that the product is not really a good quality thing ....( the importer say that is excelent quality )
the second thing is that kss 151 comes in two types one with 17 pins and the other with 18 ( if i remember correct ) so you need to let me know what do you want and i can ship it for you ....
best regrads sakis
Excellent!!!
Thanks!
_-_-bear
sidiy,
Ok, I don't see any evidence of anything else there... but I can look. Anything else other than the Laser Diode and whatever is in the package...
The KS-151A is for the Esoteric (Teac) unit.
The first link you gave (thanks) is for the Onkyo - also very useful, thanks.
If the KS152 can be utilized, I would be surprised, but pleased.
_-_-bear
_-_-bear
sorry this is soooo late bear.
unfortunately, my wife had already disposed of the parts when i got back into town.
grumble, grumble ....
mlloyd1
mlloyd1
mlloyd1 said:bear:
if it's of any value, i MIGHT have some optical parts leftover from my DX-5700 (the model under the 7500); same optics iirc. won't be able to check for a couple weeks since i'm in another state at the moment.
dx-5700 was tank-like also, i still miss it ...
mlloyd1
In this case there are some threads here, that could be of interest:
http://www.diyaudio.com/forums/showthread.php?t=108098
http://www.diyaudio.com/forums/showthread.php?t=148414
http://www.diyaudio.com/forums/showthread.php?t=148561
http://www.diyaudio.com/forums/showthread.php?t=148559
http://www.diyaudio.com/forums/showthread.php?t=146350
http://www.diyaudio.com/forums/showthread.php?t=147659
the actually question is, from where buy companies as vcd-pickup their 780nM laser diodes for currently production.
