Carpower 4/600 IGBT. lights power and protection same time
I connected a cable bridge across the speaker terminals (+ and -) of any channel, I get 0.000V without protection mode. If I connect a 4 ohm speaker, I get 0.003v without protection mode.
I disconnect the speaker or wire of the speaker terminals and returns to protect mode.
Hello
the two transistors are 2N5401. I checked and is correct. Not short nor leaked. when connected on the plate, not heated.
The only thing I have not seen clear is the hfe gain. According to datasheet, you must be between 60 and 240 HFE, and i get results 230-240 hfe, too close to the specifications limit.
Greetings.
Yes, each resistor (R93, R92, R86, R84) have direct connection to the terminal + speaker. The resistor R75 has a direct connection to the GND speaker terminal.
The 5 resistors is a tested and work perfectly.
With the 5401s out of the circuit, install the outputs for one channel and see if that channel will produce clean output.
You will need to very closely monitor the current draw and the temperature of all components that would normally be clamped to the heatsink (or clamp them down tightly).
Keep installing outputs, checking each channel as you install its outputs.
Do all 4 channels produce clean audio?
Remember that part of the protection is disabled so you have to be careful. Using a current limiter or low rated fuse (5A) will help protect the components.
Hello
Uninstall the transistors IGBT from CH4, install the two 5401 transistors, and install the DRV6807 drivers on all channels and the protection of the amplifier disappeared.
Carefully I installed the IGBT transistors of CH1, then CH2 and CH3 and works perfectly. It has clear audio and does not have excess consumption at rest.
The problem comes back when I install the transistors IGBT from CH4, the amplifier goes back into protection.
The IGBT transistors installed in the CH4 are tested and working well .... Could it be the driver DRV6807, channel CH4 that is broken?
Greetings.
