Car Audio install Question
Ok up to the next question . I have a set of tweeters going in the kick panels see picture .
Should I add a bipolar caps to these ? I’m gonna be running crossovers thru a dsp but wondering if I should also add a bipolar cap to these tweeters ?
And if so anyone know what value cap I should add and voltage rating ?
A capacitor will protect the tweeter in case the amp ever fails in a way that drives DC to the speaker output.
Any capacitor will provide protection from DC. You'll need a capacitor that will allow all frequencies from the DSP to pass.
For an amp that will not produce significantly more than the tweeters can handle, a 100v cap would be more than enough.
Where do you want the tweeter to work from and to. 6Khz or lower? it's a 4 ohm driver. To add clarity use steep ramps
18-24db 3rd or 4th order. You can use 12 or even 6 but it is sloppy for what I do and a lot less protection. With those tweets
your not going to break the bank. But mounted in the kicks even dome have their work cut out for themselves. Good place
for a 7-8" full range.
"would have its own fuse so 3 fuses per amp". I'm sure you meant to say one fuse per amp.
I am concerned the voltage is to high for the actual OBD2 and illumination on the vehicle. It's one thing
to run higher voltage setting still and plugged into a gen set for Competition. It's a whole different thing running around town
at anything above 14.2 volts. 13.8-14.2 you will be adding liquid the standard acid/lead battery. It WILL cook a jell cell to
death in a very short time. When I say a short time I'm 68, put it in perspective. You will 1/2 the life of a battery that should last 5-7 years. When you hit 15 VDC with a 200 amp alternator, you have a good wire feed welder if your not careful.
Adding cap banks is a good idea. I use a pair of 30Fs. BE CAREFUL! Mine are in a sort of plastic armor, but big caps can
really make a noise for the shell shocked crowd. I chuckle now but it wasn't always that way. I HATE getting bit with
any unwanted voltage, but DC will fry you in a second. Use the back of you hand, with DC your hands will constrict,
you won't be able to let go.
I was in the engine room on a sea going tug. The mechanic was fried with 24VDC marine.
I was there to find out why. He did not observe a simple well known practices. He touched with the palm vs back of the hand while holding a grounded steal pipe. He was well done by the time the got to him.. Of course they were in 15 foot seas with a dead power plant. That was a nasty job along with me feeding the sharks every 30 minutes or so.
The point is be careful. 12 volts will kill you dead with CAP BANKS or not. Pretty good fire works when they pop too. LOL
I have an after market head unit going in this build I noticed that the radio reception is very poor with the after market head unit but works perfectly fine with the stock head unit .
I’ve heard I can purchase a powered antenna adapter to boost the signal .
Since I need the adapter in a 2010 tahoe when replacing the head unit is there sick a thing as a powered one so it boosts the signal and if so where do I look ? I tried google but nothing came up about powered ones maybe I looked in the wrong spot
The antenna I’m using is good . I’m wondering if the factory antenna needs to see power ?
In the image below this is the antenna I have on my Tahoe . Not sure if it’s a powered antenna or not I think crutchfield said I needed to use the power antenna wire from the headunit and hook it up to the antenna wire on the factory harness . But it says nothing about this in the instructions. So not sure if I have to hook a wire up or not
