Small precision
MKP or MKT - you write MKP but I never heard about MKP....
I'd suggest MKP. See this for some ideas of brands.
Humble Homemade Hifi
Metallised polypropylene (MKP) are the better type of caps to use in speaker crossovers. Like these:
http://www.soundlabsgroup.com.au/c/Capacitors-Polypropylene/Capacitors+-+Poly.html
Have a look around at the projects online and you'll find most use MKP caps and very few will use MKT and I've never seen one with MMK.
Cap voltage ratings vs performance
An independent review and summary of available information on cap tests.
Capacitor voltage rating vs performance - The Classic Speaker Pages Discussion Forums
For what its worth, regarding Nicola'a 10kHz point, I received this helpful advice from Friedmann at Visaton last year,
(I hope its ok to quote him, 27/Oct/2009) :
>> "I think a peak at very high frequencies produced by a fullrange speaker is not audible. It is not comparable with a dome tweeter. In contrast a peak in the response of a dome tweeter is bothersome. I recommend testing the FRS8M and I am convinced that you will not miss a supertweeter. By the way, it is nearly impossible to add a supertweeter at such high frequency. The wavelength is so short that phase conditions are super critical. Our experience is that usually a good single fullrange sounds better than with additional tweeter." <<
but, only teenagers can hear past ~ 10kHz if they don't have hearing damage from iPods? Correct me hear, err here!
Regarding capacitor type at 10kHz, would it matter what was used? My question is: .. use as cheap as possible?
Grant
Grant
At 10kHz it's going to be a small cap so should not break the bank.
One thing that has to be considered is usually you get better results adding an inductor to the other driver (mid woofer?) which makes the summing, integration and hopefully phase better than a non filtered driver.
Anyone thought of using motor start capacitors? When I replaced one recently I was surprised to find it was Polyprop and being 5uF the right sort of value for crossovers. Also being mass produced cheaper than specialist audio caps.
My blog:
Consort3′s Blog
My blog:
Consort3′s Blog
Motor start capacitors are excellent for crossovers. Specialist audio caps are a wast of money.
Phil
Phil
Hello, can anyone tell me what type of capacitors these are? I am trying to find out what they should be replaced with, and under which circumstances. The square silver ones are in the eq circuit of my mixer.
Why change them out? Those should still be in spec.
Those are stacked film caps from Siemens. They are MKT (polyester) type with very low inductance, but sonically average.
"Sonically average" means that they are not better or worse than other brand's (WIMA, Philips, ERO etc.) similar MKT capacitors. And of course they are less in sound quality than most MKP-s, MKC-s, and varoius exotics. I've done a few thousand of hours of subjective evaluation, comparision and listening with different caps (being a speaker designer by trade), so I have some idea of what I hear. If you are in the same trade, welcome for a discussion....
Those are polyester layer. Like this, used in opamp circuits:
Polyester Layer 0.47uF Capacitor | Maplin
Just for fun, here below is what Harbeth use in their crossovers. MKP's (aka Polyester) and surprise, surprise, ferrite core in tweeter crossovers. So what do you know?
- Capacitor quality for crossover
