Can't identify this tube?
Any ideas 😕 as a friend suggested, its like a beefed up 807
No top cap
Octal base
large plate support
Cheers
Hi your valve looks very much like an old Navy type full wave rectifier
I don't think so. You can see the lower end of the grid wires in the first photo. There are also other internal connections between the cathode and anode structures, and maybe a couple of beam forming plates - so my guess is a beam tetrode of some kind, but my knowledge runs out at that point.
It appears to be a beam tetrode, has very similiar looking plate to some UK ATS25 807 equivalents, connecting heaters to an adjustable supply and measuring current could yeild a clue. Dial in 6.3 volts, if it draws 0.9A you have a 807/6L6 type tube most likely.
