can your 'scope do this?
Hi, Jackinnj,
How can I get this picture on the scope? The upper is the basic sinewave, the lower is the distortion component, but they both appear at the same time at the same scope?
use an active T-notch filter -- this will give you THD+N -- to just get THD you need to count the magnitude of each harmonic -- which you can do in DSP -- design of such a filter can be found on Texas Instruments and Analog Devices websites.
fwiw -- the USB1208FS and Softwire (or other software packages) can do this pretty easily.
the 5223 example shown at the start of this thread is a scope used for low noise applications -- while technically part of the 5xxx series of boatanchors it has many of the features of the 7xxx devices but the bandwidth is quite limited.
