can you spice up a cheap sub ?
Ever have mic feedback?
what you think about this thing
PFMOD HP-Sub
Well it is definitely cheaper, but now that I think about it for live sound there is a utility piece you need anyway... The FBQ100 or one of the more expensive versions. I don't think any of the amps with DSP have this feedback eliminator technology yet. You could always go simple on the amps and get a DriveRack between the amps and mixer.
So Neo what plans you suggest to build a 15" or 12" sub
or what driver to change the one that came with the nady
Ok so i removed the grill and removed the driver i will post some pics tomorrow
it is a no name thing ,no make....nothing just the bare metal...the material is 1/2 inch compressed cheapnot birch or any wood but the walmart like cofee table thing also it have a sub filter than many people report to make it smoke....will post some pics soon
I did, JBell's SS15
We knew this already, but why no pics??? 😛
ok the dimmensions of the box are
1/2" material
22 High
17 1/2 wide
15 1/4 deep
the tubes are 4" in length
and between 2 1/2 and 2 3/4 diameter
there are no internal foaming
pics attached
they are not so high res as i have used my crappy cell
More like $5-$20 in china. You're going to return this, right???
yeah 🙁
so THAM15 or SS15 jbell
also i want to use those light neodymium magnets that are super light
i dont mind to sacrifice a couple of db's
also i want to use 12mm wood with braces instead of 18mm without
have read that 12mm with braces is same efficient as 18mm but without the added weight
yeah 🙁
I was just going to say that you could do better for $129:
http://www.amazon.com/JBL-GT5-15-15-Inch-Single-Voice-Coil-Subwoofer/dp/B003KN2TMG
http://static.highspeedbackbone.net/pdf/JBL GT5-15 Subwoofer Data.pdf
Find some free wood, etc......
The JBL recommended enclosure in the PDF I linked to.
\ohhh i c them now
hey , i liked the ported design, can we got something more "loud"
that driver only gets up to 95db's at the highest wattage of the driver
but i think if we want more db's out we need a bigger power driver and a folded horn box, mmmm
can we get a poor man's SS15 ?
using 1/2 wood and some lest costly driver than the 299 bucks ones they are using
maybe a 120 bucks driver
and if i want to make the JBL ported box, i will need to hit the inside volume right ? doesnt matter if it is a cube or a rectangle shaped box, as long as i follow up the volume spec and the port size and lenght of the tube
