Ever have mic feedback?
Well it is definitely cheaper, but now that I think about it for live sound there is a utility piece you need anyway... The FBQ100 or one of the more expensive versions. I don't think any of the amps with DSP have this feedback eliminator technology yet. You could always go simple on the amps and get a DriveRack between the amps and mixer.
what you think about this thing
PFMOD HP-Sub
So Neo what plans you suggest to build a 15" or 12" sub
or what driver to change the one that came with the nady
Ok so i removed the grill and removed the driver i will post some pics tomorrow
it is a no name thing ,no make....nothing just the bare metal...the material is 1/2 inch compressed cheapnot birch or any wood but the walmart like cofee table thing also it have a sub filter than many people report to make it smoke....will post some pics soon
I did, JBell's SS15So Neo what plans you suggest to build a 15" or 12" sub
We knew this already, but why no pics??? 😛
ok the dimmensions of the box are
1/2" material
22 High
17 1/2 wide
15 1/4 deep
the tubes are 4" in length
and between 2 1/2 and 2 3/4 diameter
there are no internal foaming
pics attached
they are not so high res as i have used my crappy cell
1/2" material
22 High
17 1/2 wide
15 1/4 deep
pics attached
yeah thats what china make for 129 on the local guitar centerWow, thats crazy.
i bet that thing cost 50 bucks to make and the rest is spread on import taxation
plus the slice for GC
More like $5-$20 in china. You're going to return this, right???
yeah 🙁
so THAM15 or SS15 jbell
also i want to use those light neodymium magnets that are super light
i dont mind to sacrifice a couple of db's
also i want to use 12mm wood with braces instead of 18mm without
have read that 12mm with braces is same efficient as 18mm but without the added weight
yeah 🙁
I was just going to say that you could do better for $129:
http://www.amazon.com/JBL-GT5-15-15-Inch-Single-Voice-Coil-Subwoofer/dp/B003KN2TMG
http://static.highspeedbackbone.net/pdf/JBL GT5-15 Subwoofer Data.pdf
Find some free wood, etc......
Amazon.com: JBL GT5-15 15-Inch Single-Voice-Coil Subwoofer: Car Electronics
ok so the driver looks like is for car subs , can i fit it in an SS15 ?
or on what enclosure
The JBL recommended enclosure in the PDF I linked to.
\ohhh i c them nowThe JBL recommended enclosure in the PDF I linked to.
hey , i liked the ported design, can we got something more "loud"
that driver only gets up to 95db's at the highest wattage of the driver
but i think if we want more db's out we need a bigger power driver and a folded horn box, mmmm
can we get a poor man's SS15 ?
using 1/2 wood and some lest costly driver than the 299 bucks ones they are using
maybe a 120 bucks driver
and if i want to make the JBL ported box, i will need to hit the inside volume right ? doesnt matter if it is a cube or a rectangle shaped box, as long as i follow up the volume spec and the port size and lenght of the tube
Don't deviate from the SS15 plans or driver selection. If you do it right it'll be worth the effort/$$$.
Ayeee
hey man
what is the lightest driver you can put in there i dont care if loose a couple of dbs but i want to minimize weight
can i put those very light magnet ones ( i mean that are in the approved official list )
and can i use 1/2 birch with internal brasings
http://www.homedepot.com/h_d1/N-5yc...&keyword=1/2+birch&storeId=10051#.UGNkblHHX7Y
ic, and what is the least expensive one that can fit insde the SS15Eminence Kappalite 3015LF Neo 15" Driver will work but the lightness is gonna cost you ~$100...
- Subwoofers
- can you spice up a cheap sub ?
