Can you hear a difference between 2 solid state preamps?
Can you hear a difference between the two test files
  • I can hear a difference, but have no ABX result
    Votes: 12 50.0%
  • I cannot hear a difference and have no ABX result
    Votes: 6 25.0%
  • I can hear a difference and have an ABX result
    Votes: 4 16.7%
  • I cannot hear a difference and have an ABX result
    Votes: 2 8.3%
  • Total voters
    24
  • Poll closed .
I was doing tests with mono on my poor visitors intentionally and regularly, in the past. This time, it was a necessity, as the instrument had very different gain in both channels 😉.
What I learned here, at DIYaudio, is that it makes not much sense to argue too much. Reading and making opinion is just fine. It is much better when the discussion does not get much conflicted, for all participants.
I am pleased that, despite my annoyances with low DR recordings I can listen through and just enjoy the music.
That Claire Martin is still fine. I have just bought this
Cycles of Life | Linn Records
and this is a disappointment, DR oscillates between 6 and 8. So, even Linn Records cannot be trusted for issuing a non-compressed or minimally compressed music. Seems that only classical music and some niche jazz remains listenable.
No need you've already done that, you can't tell the difference between mono and stereo anyway from what I've heard. 😉🙂 I'm only joking....but..it does raise interesting questions about focusing during critical listening sessions don't you think?
It’s been surprising to me that the mono recordings I have tested lately (knowingly,or not!) sound so good......and I plan to do some digging on the conversion of stereo to mono.
It might just be a useless parlor trick! Gonna stay with two speakers though!
Two speaker mono is valuable and informative, it will tell much about your system.
Two speaker mono depth information is very much dependent on LR coherence.....a LR FR and timing scattered amp will not do depth information properly, a good stereo amp driven in two speaker mono tells you that the channels are matched and this allows good depth portrayal with good centre stability in terms of LR placement and centre depth positioning, ie a lousy amp will fail this listening test, a good amp excels.
Dan.
I have to agree having listened to the samples that Claire Martin doesn't sound squashed. Luckily there are still many small labels around that specialise in hight quality recordings to satisfy us.
I'll have to check back on the CD rack but a few to look at
Hyperion Records - independent British classical music record label - CDs, MP3 and Lossless downloads
Chandos Records Classical Music CDs and MP3 Downloads OnLine
Dacapo Records – the Danish national label for classical and new music
https://www.channelclassics.com/
Erased Tapes
Some of these are a little eclectic in their output.
I've also always found great quality in ECM recordings although they are known for slightly overblowing the accoustic.
Due to the press of other things, I just now have had the opportunity to listen a second time to the Claire samples. I hope any thoughts I have to share at this time will be of use.
Similar to Bill, I went into my second hearings knowing what the differences were. As I did on my initial listening, I could hear differences between Claire1 as compared to 2 and 3 which I could not tell apart. My experience is similar to Bill's: "1 does sound different."
Initially listening to the two WS samples, I felt WS2 is better. On listening and relistening to the Claire samples, I definitely preferred 2 and 3 over 1.
Also I support DNi's recommendation on MDG recordings for recording quality, I have several of MDG's recordings of chamber, piano, and orchestral music and often go back to them with pleasure.
<snip>
Changing the subject for a moment, I have some trouble seeing the point of these listening comparison threads. Guess they might sway a few skeptics to accept that we may be able to hear some things that didn't seem possible before. Other than that, is anything useful coming out of it or is it just something to do solely for entertainment?
It seems to be an attempt to try a more qualitative approach instead of the usual quantitative test method.
As matching/synchronizaion of the vocabulary is missing, the results (or meaning of the descriptions) are a bit vague, but are interesting nevertheless.
I think one of the interesting questions is, if one can dismiss any kind of published sighted reviewing process while appreciating the same kind of process in a forum.
Does publishing involve the exchange of money?
Isn't that another argument than before?
Usually - at least that was my impression - the argument was about the delusion of reviewers/writers and readers to believe in audible differences that were not based on soundfield differences.
Therefore it seemed to be kind of paradigma change, similar to the recent discussion in the blowtorch thread about (allegedly) existing audible differences when comparing old and new opamps in (nonpathologic behaving) circuits.
When's the last time you heard/saw a bad review?
"This thing is a load of crap, you don't need it and you shouldn't want it" would totally kill a reviewer's career. So we get nice glowing reviews for some of the most mediocre stuff imaginable.
Isn't it about time we realized that paid reviews are nothing more than a sales pitch for a new product?
