I've been attempting to reverse engineer the crossovers of vintage ADS speakers using the schematic attached. While calculating the quality factor, or "Q", of the second-order crossovers, I observed that the values were quite low in all crossovers, mostly below the defined range, such as in the Linkwitz-Riley (Q = 0.5) alignment.
For example, the woofer of the L730, with L = 3.50 mH, C = 33 uF, and Re = 3 Ohms, yields a Q of 0.291. Also true for the majority in the diagram.
I conjecture that the low Q was designed to provide increased impedance at the crossover region. Am I correct?
