Can I do this to stay away from crossover's low impedances?
I've been attempting to reverse engineer the crossovers of vintage ADS speakers using the schematic attached. While calculating the quality factor, or "Q", of the second-order crossovers, I observed that the values were quite low in all crossovers, mostly below the defined range, such as in the Linkwitz-Riley (Q = 0.5) alignment.
For example, the woofer of the L730, with L = 3.50 mH, C = 33 uF, and Re = 3 Ohms, yields a Q of 0.291. Also true for the majority in the diagram.
I conjecture that the low Q was designed to provide increased impedance at the crossover region. Am I correct?
Designing a proper crossover is always dependent upon the drivers used > their response & impedance.
The general starting point is using "Constant K" formular and then tweaking from there.
Constant K does not create impedance dips. 'M' derived component combinations start to impact impedance.
When you use L/C combinations that create impedance dips, you inherently create a peak in driver output.
Hence, we try to stay away from 'over reactive' L/C combinations.
In fact, unless you are trying to force an increased output of Fx in a driver, we do not use L/C combinations
that create that. Highly reactive L/C combinations not only create impedance implications, but also sonic.
Resistive attenuation techniques can also impact impedance, but that is a different subject.
(I still believe that you are using some kind of info. or software that is 'leading you astray')
Yes there is, but why would they accept this compromise?
IMHO, as can be seen in the schematic, the drivers utilized have a very low Re, i.e., woofers in a 2.8-3.0 Ohms range. This, I assume, is why they need to build the crossovers so that they cannot produce any lower impedances. And, if my hypothesis is accurate, then the low-Q design was one of the approaches they used.
What you'll also see is an impedance peak at a standard cross. This is because of the typical use of -6dB, since that is one quarter the power for each.. so an impedance shortfall could be made up there. 2.8-3.0 ohms for Re is standard for four ohm drivers.
Is there Thiele Small parameters for these drivers?
Or manufacture data showing free air impedance curve
But yes, as mentioned the crossover points will likely be closer to
impedance rise. So actual Q be different.
Seems about right. Real world be closer to .5 or .7
makes more sense and much easier to grasp when working
with the actual driver impedance curve.
Specially now since its easy to observe behavior in a model.
Looking further at your schematic diagram, it appears that you may be wanting to make a 6-8 ohm speaker system
using ~ 4 ohm drivers. This is not a practical endeavor and would require power loosing resistors.
If you are trying to use 4 ohm car audio drivers for home HiFi, you should use an amplifier that can drive 2 ohm loads.
With that kind of amp you won't need to worry much about crossover design, giving you 'free reign' of design options.
