can CDPro2 reclock with Big Ben
ackcheng said:
May be I am wrong, but I have an impression that if I connect the transport with BB through AES, the output from BB will be reclocked?
Hi
That is correct, but my experience shows the major step forward is to replace the master clock with low jitter. Once you've done that you can always reclock SPDIF (using that same master clock)
it is cheaper as well.....
cheers
ackcheng said:
Thanks Guido,
I have come across a few pictures on this site
http://www.daisy-laser.nl/homeoptics/
but the pictures of the "syrgery" is not enlargable. How likely do you think this tweak will damage the PCB of the CDPro?
Hi
It all depends on your skills and experience, I've done a few, and many daisy customers did as well, no problems reported so far
If you are in doubt, do not do it unless you find a skilled person beside you.
cheers
