It is surprising the CPAL team would not be interested in wasapi exclusive mode. E.g. the host layer was added which goes directly towards this Provide a `Host` API? (A path towards supporting alt-backends like ASIO, Windows Exclusive Mode, PulseAudio, Jack) * Issue #204 * RustAudio/cpal * GitHub -> Introduce a `Host` API by mitchmindtree * Pull Request #289 * RustAudio/cpal * GitHub. IIUC the intended way would be a new host API implementation wasapi_exclusive assigned to the windows cpal/mod.rs at master * RustAudio/cpal * GitHub
I tried to start a discussion to sort out some details before doing any work. But I never got any reply, and I interpreted that as lack of interest. It didn't exactly encourage me to spend time on it
[Wasapi] Support for exclusive mode? * Issue #459 * RustAudio/cpal * GitHub
If CamillaDSP does not in it's linux flavor, then at least it's not a CamillaDSP issue: The Digiface USB device does not provide class compliant mode and probably never will. Therefore chances are very small that it will ever work under Linux.
Have a look at: is DigiFace USB Class Compliant? (Page 1) — FireWire & USB series — RME User Forum
Way fwd???
RME Digiface USB - Linux - Ardour
See last post... a Digiface and a Pi4 would be yummy 🙂 but I'm no programmer...
For my prof of concept is used a setup like this in my little office:Your earlier post said it sounded really good over two days of listening yet this sounds like it clearly failed. Can you elaborate a bit more on what didn’t work and how you reached your conclusion.
Bit I’m particularly interested in is whether the USB devices stayed aligned with each other as it would really widen the options if I didn’t need a multichannel dac for my actives.
Tweeters -> USB DAC 1 -> Cheap Headphones
Mids -> Macbook Integrated Speakers
Bass -> DAC 2 -> Old Subwoofer
And it works quite well - no apparent problems with sync - but then again I was not listening that detailed...
TNT: Damien is very competent, no doubts. I would be a bit afraid of the two bulk output endpoints - could be some DSP firmware upload - e.g. either for upgrading a firmware in flash (good) or for uploading to SRAM/FPGA (bad).
Anyway for testing you do not need to be a programmer - just adding the code to the file Damien mentions and re-compiling kernel.
OK! Recompiling requires "programming" skills ;-) - but I see what you mean... and I don't even have the insight to grasp your concern re "upload" - hacking??
Do you believe it could work?
Actually it's mostly copy/paste a few commands from some tutorial, e.g. Kernel/BuildYourOwnKernel - Ubuntu Wiki . The debian/ubuntu process is simple:
* download pre-configured kernel sources of the currently running kernel (apt source ...)
* compile + build packages + install them + reboot to the new kernel to test the process - this takes a while (the linked tutorial does not compile with multiple cores but that is a trivial modification)
* make changes to the files - only adding the quirk code to that file
* re-compile - this is fast as only the usb-audio module will be compiled
* overwrite the existing module file with the new one or build packages + re-install them
I did not mean to hack/reverse-engineer the communication. I am just afraid the bulk endpoints may be used actively when configuring the device before it resorts to some (often customized) usb-audio protocol. Or maybe not. Capturing the USB communication in windows with wireshark would tell but still there would likely be a long way to learning all the details.
Damien looked at the device USB configuration (as reported by lsusb -v) and made some very logical/experienced guesses in his quirk. But the reality can be quite different, and only testing his quirk would tell.
On the other hand, if proper support required only that simple quirk (which just hard-codes missing USB configuration options - a correct USB audio device would report them all by itself), why would RME flat refuse to do it, if some of their other soundcards have excellent (and quite complicated) alsa drivers...
"Actually is mostly..." for someone who is used to these things it might be "it's mostly" but for me it would be a hard thing to do really 🙂
Thanks for your answer!
Everything is hard the first time, for everyone. If you want to (and have the soundcard + some reasonable PC with ubuntu/debian), we can try it (in another thread, of course).
CamillaDSP + Asus Xonar U7 MKII - a winning combination
Hi All,
Now using Asus Xonar U7 MKII + CamillaDSP - and that works !
The Asus Xonar U7 MKII is a 7.1 USB "surround processor" - which actually has 8 x DAC capable of 24bit/ 192Khz - with a SINAD of 102db - not bad for a €90 box.
I have the Asus Xonar U7 MKII acting as front end to a CamillaDSP with a 3 way filter - and there are NO issues with the stereo perspective - the 8 DAC's are perfectly synchronized.
Additional info - you can use the Xonar as a 2, 4, 6 or 8 way DAC.
Hi All,
Great! One thing, that is easy to overlook, is that the dacs and amplifiers get a much easier job when each channel only needs to handle a fraction of the frequency range. So you can get away with using cheaper dacs and amps, and the difference when upgrading to something better might not be that big.
Hi All,
Does the U7 work on Windows or Linux?
The Asus U7 MKii works with Windows -> Xonar U7 MKII - Tech Specs|Sound Cards|ASUS Global
And probably with Linux too - but I have not tried that.
Thanks a bunch for the offer - appreciated. I'm on OSX - is that a hinder?
I would like to run the Digiface from a Pi.
TNT: I am afraid you really need to run linux to compile linux kernel and test its module.
You could compile on RPi but it will take forever and the SD card will not be happy. Any reasonable amd64 machine with SSD drive/8GB RAM would do. You can compile & test on x86, USB device drivers use identical source code for any architecture.
VB is OK for compilation, but for testing it presents another layer of complexity. VB supports redirecting USB devices to guests (e.g. How to Access USB from VirtualBox Guest OS - LinuxBabe in linux host) but if the soundcard does not work in the guest, is the problem in the patched driver or in the redirection of raw USB device to the VB guest (or both co-operation with the patched driver)? Too many degrees of freedom...
You can crosscompile for RPi in VB, but that takes much more effort than native kernel compilation + installing onto RPi ... to learn the patch does not work.
Is there a way to plot the "end to end" frequency and phase response of a pipeline ?
When I run plotcamillaconf it plots freq and phase for each individual filter and eq - It would be really useful to be able to plot "end to end"
- PC Based
- CamillaDSP - Cross-platform IIR and FIR engine for crossovers, room correction etc
