To my surprise, pCP actually have a pkg-config.tcz packet, so I installed it - but as I said, it didn't find any alsa package.
But alsa was kind enough to tell me the right path, when I took a chance with the wrong...
If this alsa-plugin turns out well, I guess Jesper (lykkedk) might come up with a tcz-pacet for pCP. If not seashell..?
Jesper (and partly I) has already almost finished creating tcz packets with CamillaDSP, and my scripts for a piped setup.
And then seashell shows up and wipes the table... Oh, well... what can you do... Adapt and Redo... 🙄
I won't be making packages for any distribution. And nothing requires you to scrap what you've done and use the plugin. Nothing was changed in camilla to accommodate the plugin.
Hi here 😉
And with @seashell's comment ::
I will try to make an extension for the pCP... good evening gentlemen 😛
Jesper.
Report Post Reply With Quote
Jesper.
Of course! It still works as intended.... And nothing requires you to scrap what you've done and use the plugin...
It just became - let's say: kind of obsolete - or: less interesting to go on with...
But it has a bit different approach, so it might still be a good alternative to have around. And it's certainly not wasted work. I do it for fun, and have learned a lot... And as long as I get something better - I'm happy..! 🙂
Great work is done on this auto sample rate switching 🙂
@Seashell's alsa plugin seem's like the most native solution for this.
Well, i used a lot of time figuring out howto set this up.
I finally managed to have it run through.
Now i feel a little st.... asking this, but i have filters (.yml) for each samplerate
How do i make this plugin use them?
Proberly easy to do??? -I just can't figure it out 😕
My filters are build up like this:
I have cut the head of the .yml out for clearness 🙂
My /etc/asound.conf looks like this::
Jesper.
Code:
filters:
L_prefir:
type: Conv
parameters:
type: File
filename: /home/tc/DSP_Engine/filters/44100/L_avg_RPfir_44100.bin
format: FLOAT32LE
R_prefir:
type: Conv
parameters:
type: File
filename: /home/tc/DSP_Engine/filters/44100/R_avg_RPfir_44100.bin
format: FLOAT32LE
L_fir:
type: Conv
parameters:
type: File
filename: /home/tc/DSP_Engine/filters/44100/L_avg_NORMAL_44100.bin
format: FLOAT32LE
R_fir:
type: Conv
parameters:
type: File
filename: /home/tc/DSP_Engine/filters/44100/R_avg_NORMAL_44100.bin
format: FLOAT32LE
clipgain_L:
type: Gain
parameters:
gain: -12.0
inverted: false
clipgain_R:
type: Gain
parameters:
gain: -12.0
inverted: false
pipeline:
- type: Filter
channel: 0
names:
- L_prefir
- type: Filter
channel: 1
names:
- R_prefir
- type: Filter
channel: 0
names:
- L_fir
- type: Filter
channel: 1
names:
- R_fir
- type: Filter
channel: 0
names:
- clipgain_L
- type: Filter
channel: 1
names:
- clipgain_R
Code:
# "sound_out" is the "real" hardware card (usbdac, soundcard etc...)
pcm.sound_out {
type hw
card 0
device 0
#--- CamillaDSP with alsa-plugin ---
pcm.camilladsp { # You can use any name, not just camilladsp
type cdsp
cpath "/usr/local/bin/camilladsp"
config_in "/home/tc/camilladsp/template/config_template.yml"
# If using symlinks for switching configs:
# config_in "/home/tc/camilladsp/config_template.yml"
# config_cmd "/path/to/more_complex_yaml_creator
config_out "/home/tc/camilladsp.yaml"
# Additional arguments to CamillaDSP. Numeric arguments must be quoted in strings
# -p "1234"
cargs [
-l warn
-p "1234"
channels 2
rates = [
44100
48000
88200
96000
176400
192000
352800
384000
# extra_samples 0
# extra_samples_44100 8192
# extra_samples_48000 8916
Jesper.
If you want to use completely separate yaml files you'll have to use config_cmd and make a script that will copy whichever yaml file you want to the config_out location. config_cmd will be called with the sample rate as one of the three arguments. (Order is in the docs.)
If you want to use config_in then make a single template yaml file. Assuming all your other sample rate files look the same as that one except the sample rate, just replace 44100 everywhere with $samplerate$ and the plugin will replace $samplerate$ with whatever sample rate is being used. Don't forget the samplerate in the device section as well. Look at the sample config_in.yaml.
Code:filters: L_prefir: type: Conv parameters: type: File filename: /home/tc/DSP_Engine/filters/44100/L_avg_RPfir_44100.bin format: FLOAT32LE R_prefir: type: Conv parameters: type: File filename: /home/tc/DSP_Engine/filters/44100/R_avg_RPfir_44100.bin format: FLOAT32LE L_fir: type: Conv parameters: type: File filename: /home/tc/DSP_Engine/filters/44100/L_avg_NORMAL_44100.bin format: FLOAT32LE R_fir: type: Conv parameters: type: File filename: /home/tc/DSP_Engine/filters/44100/R_avg_NORMAL_44100.bin format: FLOAT32LE clipgain_L: type: Gain parameters: gain: -12.0 inverted: false clipgain_R: type: Gain parameters: gain: -12.0 inverted: false pipeline: - type: Filter channel: 0 names: - L_prefir - type: Filter channel: 1 names: - R_prefir - type: Filter channel: 0 names: - L_fir - type: Filter channel: 1 names: - R_fir - type: Filter channel: 0 names: - clipgain_L - type: Filter channel: 1 names: - clipgain_R
Code:# "sound_out" is the "real" hardware card (usbdac, soundcard etc...) pcm.sound_out { type hw card 0 device 0 } #--- CamillaDSP with alsa-plugin --- pcm.camilladsp { # You can use any name, not just camilladsp type cdsp cpath "/usr/local/bin/camilladsp" config_in "/home/tc/camilladsp/template/config_template.yml" # If using symlinks for switching configs: # config_in "/home/tc/camilladsp/config_template.yml" # config_cmd "/path/to/more_complex_yaml_creator config_out "/home/tc/camilladsp.yaml" # Additional arguments to CamillaDSP. Numeric arguments must be quoted in strings # -p "1234" cargs [ -l warn -p "1234" ] channels 2 rates = [ 44100 48000 88200 96000 176400 192000 352800 384000 ] # extra_samples 0 # extra_samples_44100 8192 # extra_samples_48000 8916 }
Jesper.
Here is the config_in and asound I am using. You need to rename you filter files to something like 44100L.dbl, 44100R.dbl etc
Ahhh...
I get it now; thank's both 😉
I need to understand this before i can make some install files.
Jesper.
Jesper.
I think your filter names are probably fine. Just change this
to this
filename: /home/tc/DSP_Engine/filters/$samplerate$/R_avg_RPfir_$samplerate$.bin
Then for 44100 it will become (as it was originally)
And for say 96000 it would be
filename: /home/tc/DSP_Engine/filters/96000/R_avg_RPfir_96000.bin
It's literally a simple global search and replace. Where $samplerate$ exists it gets replaced with the sample rate. Same with $format$, etc.
And thanks @wineds, glad it's working well for you.
to this
Cool 🙂
So this is what i have to do ?
/home/tc [tree]
camilladsp
├── coeffs
├── configs
├── filters
│ ├── 176400
│ ├── 192000
│ ├── 44100
│ ├── 48000
│ ├── 88200
│ └── 96000
└── template
└── config_template.yml
And the config_template.yml
And the asound.conf
Please comment the RED text
Is this correct then ?
Jesper.
/home/tc [tree]
camilladsp
├── coeffs
├── configs
├── filters
│ ├── 176400
│ ├── 192000
│ ├── 44100
│ ├── 48000
│ ├── 88200
│ └── 96000
└── template
Code:
devices:
samplerate: $samplerate$
chunksize: 4096
queuelimit: 1
capture:
type: File
channels: $channels$
filename: "/dev/stdin"
format: $format$
playback:
type: Alsa
device: "sound_out"
format: S32LE
filters:
l_prefir:
type: Conv
parameters:
type: File
filename: /home/tc/camilladsp/filters/$samplerate$l_prefir.bin
format: FLOAT32LE
r_prefir:
type: Conv
parameters:
type: File
filename: /home/tc/camilladsp/filters/$samplerate$r_prefir.bin
format: FLOAT32LE
l_fir:
type: Conv
parameters:
type: File
filename: /home/tc/camilladsp/filters/$samplerate$l_fir.bin
format: FLOAT32LE
r_fir:
type: Conv
parameters:
type: File
filename: /home/tc/camilladsp/filters/$samplerate$r_fir.bin
format: FLOAT32LE
clipgain_l:
type: Gain
parameters:
gain: -10.0
inverted: false
clipgain_r:
type: Gain
parameters:
gain: -10.0
inverted: false
pipeline:
#- type: Filter
# channel: 0
# names:
# - l_prefir
#- type: Filter
# channel: 1
# names:
# - r_prefir
#- type: Filter
# channel: 0
# names:
# - l_fir
#- type: Filter
# channel: 1
# names:
# - r_fir
- type: Filter
channel: 0
names:
- clipgain_l
- type: Filter
channel: 1
names:
- clipgain_r
And the asound.conf
Code:
# --- sound_out is the real hardware card ---
pcm.sound_out {
type hw
card 0
device 0
# --- CamillaDSP with Seashell's alsa-plugin ---
# Howto here : [url=https://github.com/scripple/alsa_cdsp]GitHub - scripple/alsa_cdsp: ALSA plugin for Camilla DSP[/url]
pcm.camilladsp {
type cdsp
config_out "/home/tc/camilladsp/camilladsp.yaml" [B][COLOR="Red"]<--- [U]EMPTY file[/U] or [U]no file[/U] here ?[/COLOR][/B]
cargs [
-l warn
-p "1234"
channels 2
rates = [
44100
48000
88200
96000
176400
192000
352800
384000
Jesper.
I tried this new approach to set the sample rate for CamillaDSP. CamillaDSP runs with different settings depending on the file or stream that is played, which is good news. But, I have a few problems.Thanks to @seashell it's now easy to switch config at sample rate changes!
Take a look here: GitHub - scripple/alsa_cdsp: ALSA plugin for Camilla DSP
This is an Alsa plugin that acts as a playback device. It takes a template config file and updates the values for samplerate etc, and then launches an instance of CamillaDSP that it pipes the audio data to.
First, I run this on Ubuntu Server 20.04, on an Intel i3-4360T @ 3.2 GHz. With the "normal" configuration the problems described below does not exist.
buffer underrun
Playing with squeezelite I see this message quite frequently in the syslog:
squeezelite[393027]: 2020-11-08 12:38:39.093 WARN camillalib::alsadevice - Prepare playback after buffer underrun
I can also hear the little dropout when it occurs.
The problem seems to be more frequent at higher bitrates, but even when streaming music at 44100, the underrun occurs approximately once every or second minute. It can happen in the middle of a song for no obvious reason. Changing settings back and forth for CamillaDSP and squeezelite might have improved it a bit.
broken pipe
squeezelite[473953]: 2020-11-08 14:01:31.606 WARN camillalib::alsadevice - Retrying playback, error: ALSA function 'snd_pcm_writei' failed with error 'EPIPE: Broken pipe'
This happens rarely and for no obvious reason.
MPD running at 100 % CPU
MPD runs at 100 % when playing. Nothing in the syslog or mpd.log.
The broken pipe error is actually also a buffer underrun, one that happens in a tiny window after it checks that there hasn't been a buffer underrun (this check gives the "normal" buffer underrun message), and before it starts writing data to the device.I tried this new approach to set the sample rate for CamillaDSP. CamillaDSP runs with different settings depending on the file or stream that is played, which is good news. But, I have a few problems.
buffer underrun
broken pipe
It looks as if CamillaDSP receives samples too slowly, just slightly slower than the playback device needs them. That would give exactly these periodic underruns.
Seashell, how is the rate of the plugin set? Is it trying to follow the rate at which CamillaDSP accepts the samples, or is it fixed by some timer?
I don't have any idea about the MPD problem.
@lykkedk config_out just needs to be readable/writeable by the user than runs the playback program. It doesn't matter what's in it as it will be overwritten.
I think you're missing a / after your $samplerate$ in your filters if they're in subdirectories.
@audiac sorry you're having trouble. Yes @Henrik there's a fake clock that in theory just throttles the write speed if things are going too fast, but I can see where it can cause the underrun problem. My implementation is based on bluez_alsa because the fake clock is so annoying. But looking more closely I'm not sure I'm seeing any advantage to it with blocking writes.
@audiac please comment out one line of code and see what happens.
This is line 312 (or close - I might have some test edits.)
Change that to
And redo the make / make install. Then see what happens.
Code:
// synchronize playback time
asrsync_sync(&asrs, frames);
Change that to
Code:
//asrsync_sync(&asrs, frames);
I cannot notice any difference.
The buffer underruns occur as often as before when playing with squeezelite.
MPD still at 100 %.
MPD still at 100 %.
Sorry, no idea then. That line removes the only "clock" in the plugin. After that it's just throttled by how fast camilla reads from the pipe. There was a bug that caused the mpd 100% but it was fixed before I made the repo public and I assume you've not checked out old commits.
@Seashell... it's working 🙂
I actually mamaged to pack it all up in squeezed (piCore .tcz) filesystem :
Code:
lykke@Lykkedk:~/Desktop/superplayer_08112020$ tree seashellPackage
seashellPackage
├── home
│ └── tc
│ ├── asound.conf.tar.gz
│ └── camilladsp.tar.gz
└── usr
└── local
├── lib
│ └── alsa-lib
│ └── libasound_module_pcm_cdsp.so
└── tce.installed
└── seashell_alsa
7 directories, 4 files
lykke@Lykkedk:~/Desktop/superplayer_08112020$ tree camilladsp
camilladsp
├── camilladsp.yaml
├── coeffs
├── configs
├── filters
│ ├── 176400
│ ├── 192000
│ ├── 44100
│ ├── 48000
│ ├── 88200
│ └── 96000
└── template
10 directories, 2 files
lykke@Lykkedk:~/Desktop/superplayer_08112020$ tree camilladsp-package
camilladsp-package
└── usr
└── local
├── bin
│ └── camilladsp
└── tce.installed
└── camilladsp
4 directories, 2 files
I just need some more test's to see if everything is 100% (or likely 90%) perfect, before i do more. -Need to test on a clean system from scratch also 😀
But it's a really good solution seashell...
Jesper.
Thanks anyway! I've used the master branch of alsa_cdsp and CamillaDSP 0.4.0 beta 6. I'll try some more and maybe I'll come back with more questions.Sorry, no idea then. That line removes the only "clock" in the plugin. After that it's just throttled by how fast camilla reads from the pipe. There was a bug that caused the mpd 100% but it was fixed before I made the repo public and I assume you've not checked out old commits.
Oh, @audiac one other thing. After you do the sudo make install you need to kill any running mpd / squeezeilte processes and restart them. Otherwise they will not reload the changed plugin and obviously there would be no difference.
Stopping/starting playback is not sufficient.
You can also force the clock to be a problem. From the original code (with the asrsync_sync(&asrs, frames); call active) replace both instances of
asrsync_init(&asrs, io->rate);
with
asrsync_init(&asrs, 0.9*io->rate);
This should create constant underrun warnings from camilla. That way you'll know the changes are doing something.
with
- PC Based
- CamillaDSP - Cross-platform IIR and FIR engine for crossovers, room correction etc
