I got pip3 installed.
And: pip3 install yaml-utilities
Now a yaml module is imported. But... not good enough..?
Error at the first it's called:
Code:
tc@SqueezePi2:~$ sudo /home/tc/camilladsp/camilladsp -p1234 -v -w 2> /home/tc/DSP_Engine/camilladsp.log &
tc@SqueezePi2:~$ sudo squeezelite -n SqueezePi2 -o camillapipe -a 160:4::1 -b 10000:20000 -r 44100-192000:2500 -s 192.168.1.5
Traceback (most recent call last):
File "/home/tc/camilladsp/camillapipe.py", line 46, in <module>
main()
File "/home/tc/camilladsp/camillapipe.py", line 23, in main
config = yaml.load(f, Loader=yaml.SafeLoader)
File "/usr/local/lib/python3.6/site-packages/yaml/__init__.py", line 112, in load
loader = Loader(stream)
File "/usr/local/lib/python3.6/site-packages/yaml/loader.py", line 34, in __init__
Reader.__init__(self, stream)
File "/usr/local/lib/python3.6/site-packages/yaml/reader.py", line 85, in __init__
self.determine_encoding()
File "/usr/local/lib/python3.6/site-packages/yaml/reader.py", line 124, in determine_encoding
self.update_raw()
File "/usr/local/lib/python3.6/site-packages/yaml/reader.py", line 178, in update_raw
data = self.stream.read(size)
File "/usr/local/lib/python3.6/encodings/ascii.py", line 26, in decode
return codecs.ascii_decode(input, self.errors)[0]
UnicodeDecodeError: 'ascii' codec can't decode byte 0xc3 in position 14: ordinal not in range(128)
Thanks! I'll write something to the mailing list.IMO shortly describing your use case may do, either as a continuation of that thread or a new one with link to the previous "outcome".
I didn't hink about combining the pipe stuff with hooks. That could be a winner, will try it when I have a little time.Henrik to capture this behavior you can still use the pcm_hook even if avoiding loopback. Wrap the alsa file in the alsa hook and use either sighup or the websocket to tell camilla to update the parameters.
You don't need the first camilladsp command! The camillapipe.py script starts camilladsp for you.I got pip3 installed.
Code:tc@SqueezePi2:~$ sudo /home/tc/camilladsp/camilladsp -p1234 -v -w 2> /home/tc/DSP_Engine/camilladsp.log & tc@SqueezePi2:~$ sudo squeezelite -n SqueezePi2 -o camillapipe -a 160:4::1 -b 10000:20000 -r 44100-192000:2500 -s 192.168.1.5 Traceback (most recent call last): File "/home/tc/camilladsp/camillapipe.py", line 46, in <module> main() File "/home/tc/camilladsp/camillapipe.py", line 23, in main config = yaml.load(f, Loader=yaml.SafeLoader) File "/usr/local/lib/python3.6/site-packages/yaml/__init__.py", line 112, in load loader = Loader(stream) File "/usr/local/lib/python3.6/site-packages/yaml/loader.py", line 34, in __init__ Reader.__init__(self, stream) File "/usr/local/lib/python3.6/site-packages/yaml/reader.py", line 85, in __init__ self.determine_encoding() File "/usr/local/lib/python3.6/site-packages/yaml/reader.py", line 124, in determine_encoding self.update_raw() File "/usr/local/lib/python3.6/site-packages/yaml/reader.py", line 178, in update_raw data = self.stream.read(size) File "/usr/local/lib/python3.6/encodings/ascii.py", line 26, in decode return codecs.ascii_decode(input, self.errors)[0] UnicodeDecodeError: 'ascii' codec can't decode byte 0xc3 in position 14: ordinal not in range(128)
But the error you get is something else, about your yaml file. Could you post it?
Your'e right - as usual...
I messed up the config path, pointing to my old config.
Fixing that, I found that I also has to edit camillapipe.py, line 42:
And then: - Well I don't really know.
It won't play if I try.
No output to the console.
When I break, I get:
Code:
subprocess.run(["/path/to/camilladsp"....
Code:
168.1.5
Rate: 44100, format: S32_LE, channels: 2
[2020-10-12T20:37:44Z INFO camillalib::alsadevice] Starting playback from Prepared state
^CTraceback (most recent call last):
main()
File "/home/tc/camilladsp/camillapipe.py", line 42, in main
subprocess.run(["/home/tc/camilladsp/camilladsp", "-p1234", "/tmp/camilladsp.yml"], stdin=sys.stdin.buffer)
File "/usr/local/lib/python3.6/subprocess.py", line 405, in run
stdout, stderr = process.communicate(input, timeout=timeout)
File "/usr/local/lib/python3.6/subprocess.py", line 835, in communicate
self.wait()
File "/usr/local/lib/python3.6/subprocess.py", line 1457, in wait
(pid, sts) = self._try_wait(0)
File "/usr/local/lib/python3.6/subprocess.py", line 1404, in _try_wait
(pid, sts) = os.waitpid(self.pid, wait_flags)
KeyboardInterrupt
and this is the requested .yml, picked up from /tmp:
Code:
tc@SqueezePi2:~$ cat /tmp/camilladsp.yml
devices:
adjust_period: 5
capture:
channels: 2
format: S32LE
type: Stdin
chunksize: 4096
enable_rate_adjust: true
playback:
channels: 2
device: sound_out
format: S32LE
type: Alsa
queuelimit: 0
samplerate: 44100
target_level: 2048
filters:
clipgain:
parameters:
gain: -12.0
inverted: false
type: Gain
pipeline:
- channel: 0
names:
- clipgain
type: Filter
- channel: 1
names:
- clipgain
type: Filter
Let's get you some output in the console. Edit line 42 to this (Add the -vv flag):Fixing that, I found that I also has to edit camillapipe.py, line 42:
And then: - Well I don't really know.Code:subprocess.run(["/path/to/camilladsp"....
Code:
subprocess.run(["/path/to/camilladsp", "-p1234", "-vv", "/tmp/camilladsp.yml"], stdin=sys.stdin.buffer)
@ TNT:
Well... clipgain also serves as level adjustment to match my room EQ filters. I experiment with pretty high gain i some bass peaks.
@ Henrik:
I was wrong - again.
It can play - almost. And it took a long time, several minutes before first sound-blip. It plays short blips of maybe 0.1 second, and then pauses 5-20 seconds. Total CPU load is < 5%
Interesting...
@ Henrik:
Interesting...
There is no single value for the clipgain that will always work. With a FIR filter, the maximum possible value is the sum of the absolute value of the filter coefficients. For a long filter this could become large. You need a very specific signal for that to happen though, so it will most likely never reach this value."clipgain" is generous... theoretically -3,1 dB should suffice I think...
Anyway, around -3 dB is a good start, and then increase the attenuation a little if you see clipping sometimes.
That seems pretty odd. Maybe try changing queuelimit to 1 in the template.@ TNT:
@ Henrik:
Interesting...
You can also remove the enable_rate_adjust, adjust_period and target_level parameters from the template, rate adjust isn't used here anyway.
I don't think the pcm_hook and file are compatible at least for this use case. file doesn't create anything under the proc file system, and alsa doesn't pass the hw_params to the hw_params hook call. (Why??)
Anyway, I just updated the hook to make everyone's life easier. It does the parsing in the hook itself and passes "format rate channels" to the open command.
With commands 'echo open' and 'echo close':
Code:
aplay -D lbparams -r 48000 -f S32_LE -c 2 < /dev/random
close
Playing raw data 'stdin' : Signed 32 bit Little Endian, Rate 48000 Hz, Stereo
open S32_LE 48000 2
^CAborted by signal Interrupt...
close
@Henrik...
So i have as you know a working camillagui installed on my pCP/SuperPlayer_v2.0
The webinterface shows what it should without the plotting function as expected. -This if because i don't have mathplotlib, numpy etc. installed.
Well, i had this on my mind if it was possible somehow to make the SuperPlayer send the "plotting" information via lan, whatever to my laptop.
Then on my laptop i can ran the heavystuff so to see the plotting.
I'am not sure it's possible at all, but could be very cool in such situations where the stuff is running on a lowspec. hardware platform aka' raspberry pi's (especially pCP/Tinycore which resides in RAM)...
Just a crazy thought
Jesper.
Jesper.
No that's not a crazy idea....
That is of course the proper way to do it. The only reason I use numpy+matplotlib to generate images server-side is because it allows me to reuse the existing python code for evaluating the various filters. I want to get away from this at some point, but to get there I have to rewrite a lot of python code in javascript. This will take quite some time (especially since I'm not very good with js).Let the browser do the graphing work with some java-script...
It's the other way round Resolution in Hz = Sampling Frequency / Taps (Co-efficients), I think you know that but just to be clear for anyone else
Taps / Sampling Frequency gives you filter length in seconds.
Thank you Fluid.
Lower sampling = steeper filters and narrower dips and peaks.
Just on a sidenote to advocate against my suggestion. Steeper filters and narrower dips and peaks of the filters can be bad for sound quality. So have a eye on the group delay!
I also have bursts of plipps and plopps... their duration is typically during say 2-15 seconds and these bursts re-occur anything between 2-3 minutes to 15 minutes.
My setup...
Camilla in a Mac Mini (1 TB SSD, one logical core out of 8 show 20% load) feeding a RME Digiface USB... over USB
Did Save from GUI:
devices:
adjust_period: 10
capture:
channels: 2
device: Soundflower (2ch)
format: FLOAT32LE
type: CoreAudio
capture_samplerate: 0
chunksize: 32768
enable_resampling: false
playback:
channels: 2
device: Digiface USB (24007543)
format: FLOAT32LE
type: CoreAudio
queuelimit: 100
resampler_type: BalancedAsync
samplerate: 44100
silence_threshold: 0
silence_timeout: 0
target_level: 16384
filters:
-6dB:
parameters:
gain: -6
inverted: false
type: Gain
lowpass_fir:
parameters:
filename: /Users/audio1/Documents/Ca+Di/Camilla/FIRs/eggPhase.txt
format: TEXT
read_bytes_lines: 0
skip_bytes_lines: 0
type: File
type: Conv
mixers: {}
pipeline:
- channel: 0
names:
- lowpass_fir
- -6dB
type: Filter
- channel: 1
names:
- lowpass_fir
- -6dB
type: Filter
My setup...
Did Save from GUI:
devices:
adjust_period: 10
capture:
channels: 2
format: FLOAT32LE
type: CoreAudio
chunksize: 32768
playback:
channels: 2
format: FLOAT32LE
type: CoreAudio
queuelimit: 100
samplerate: 44100
silence_timeout: 0
target_level: 16384
filters:
-6dB:
parameters:
gain: -6
inverted: false
type: Gain
lowpass_fir:
parameters:
format: TEXT
read_bytes_lines: 0
skip_bytes_lines: 0
type: File
type: Conv
mixers: {}
pipeline:
- channel: 0
names:
- lowpass_fir
- -6dB
type: Filter
- channel: 1
names:
- lowpass_fir
- -6dB
type: Filter
Ok, I'll add that to my list.So Henrik, group delay plot in addition to frequency response and phase response can be very useful for complex filters.
The problem is most likely here:I also have bursts of plipps and plopps... their duration is typically during say 2-15 seconds and these bursts re-occur anything between 2-3 minutes to 15 minutes.
Code:
[COLOR=Olive]enable_resampling: false[/COLOR]
There is no way to adjust the rate of the SoundFlower device, so we have to use asynchronous resampling to match capture and playback rates.
- PC Based
- CamillaDSP - Cross-platform IIR and FIR engine for crossovers, room correction etc.
