I suppose it is what is loaded into the GU if you push the button "New config from Default".
Ah got it, there is room for improved here in the readme. If says the backend config is at config/camillagui.yml, and this "config" directory is a subdirectory of the backend. I'll try to clarify this.I am not editing this config file because the readme indicated that the config file that's used by the backend is in /home/mark/camilladsp/config/
Since you are using the bundle, the backend file structure is a little different. I would suggest editing the file in /home/mark/camilladsp/camillagui_backend/_internal/config/ and then you don't need the -c option when starting the backend.
I tried your suggestion and it works fine. I agree that the readme could be a little clearer. And perhaps references to /configs need to be removed, that was a confusion factor for me.
Thank you for your assistance!
YEESSSS...
I found a script to read out the mouse scroll-wheel. With a little edit I can control the volume of CDSP with a mouse scroll wheel.
Hopefully it will work with a wireless mouse with USB dongle as well... can not check at the moment, have just wired ones 😉
Python:
from evdev import InputDevice, categorize, ecodes, list_devices
import socket
import websocket
import time
import json
cmdUp = {
"AdjustVolume": [1.0, -60.0, 0.0]
cmdDown = {
"AdjustVolume": [-1.0, -60.0, 0.0]
# Config: path to CamillaDSP control socket
host = 'localhost'
port = 1234
DSP_SOCKET = (host, port)
# Adjust volume by this dB step
VOLUME_STEP = 1.0
devices = [InputDevice(path) for path in list_devices()]
mouse = None
for dev in devices:
if 'Mouse' in dev.name or 'mouse' in dev.name:
mouse = dev
break
if mouse:
print(f"Monitoring: {mouse.name}")
for event in mouse.read_loop():
if event.type == ecodes.EV_REL and event.code == ecodes.REL_WHEEL:
ws = websocket.create_connection("ws://localhost:1234")
if event.value > 0:
print("Scroll up")
ws.send(json.dumps(cmdUp))
result = ws.recv()
print("Response:", result)
ws.close()
elif event.value < 0:
print("Scroll down")
ws.send(json.dumps(cmdDown))
result = ws.recv()
ws.close()
@chriss0212
"Hopefully it will work with a wireless mouse with USB dongle as well..."
I tried for you, but it doesn't work, at least with my wireless mouse with USB dongle.
Urghh...
****, but wired mouse is working?
And: have you disconnected, the wired one before you start the script?
i don't have wired mouse...
python3 -m evdev.evtest show the wireless mouse but no events is get when whell is used
Maybe it will work with pynput if evdev is not working... on my windows laptop this snippet is working with wireless and wired mouse:
Python:
from pynput import mouse
def on_scroll(x, y, dx, dy):
if dy > 0:
print("Up")
elif dy < 0:
print("Down")
# Start the mouse listener
with mouse.Listener(on_scroll=on_scroll) as listener:
listener.join()
me too, just trying the new snippet on windows, because i don't have Raspi at work 😉i use linux headless configuration...
But i see now, that pynput only works on X11.
OK... will check later at home. Don't get, why it is not working, if the mouse is recognized... strange.i don't have wired mouse...
Yes... sorry... havn't seen this post ;(But again: i don't have wired mouse...
Maybe this could be an alternative solution?
Python:
import subprocess
proc = subprocess.Popen(['libinput', 'debug-events'], stdout=subprocess.PIPE)
try:
for line in proc.stdout:
decoded = line.decode('utf-8').strip()
print(decoded)
if 'pointer axis' in decoded and 'vertical' in decoded:
if 'value 1.0' in decoded:
print("Scrolled Up")
elif 'value -1.0' in decoded:
print("Scrolled Down")
except KeyboardInterrupt:
proc.terminate()
Requires the libinput-tools package:
Python:
sudo apt install libinput-tools
ok, it work ( original version) , my error was than my wireless mouse is listed 5 time in evdev, so i have changed your script to point to /dev/input/event2, the only than detect whell
ID Device Name Phys Uniq
0 /dev/input/event0 Aureon 7.1 USB usb-0000:01:00.0-1.3/input3
1 /dev/input/event1 MOSART Semi. 2.4G Keyboard Mouse usb-0000:01:00.0-1.4/input0
2 /dev/input/event2 MOSART Semi. 2.4G Keyboard Mouse usb-0000:01:00.0-1.4/input1
3 /dev/input/event3 MOSART Semi. 2.4G Keyboard Mouse Consumer Control usb-0000:01:00.0-1.4/input1
4 /dev/input/event4 MOSART Semi. 2.4G Keyboard Mouse System Control usb-0000:01:00.0-1.4/input1
5 /dev/input/event5 MOSART Semi. 2.4G Keyboard Mouse usb-0000:01:00.0-1.4/input1
Python:
import asyncio
import evdev
from camilladsp import CamillaClient
MOUSE_PATH = "/dev/input/event2"
cdsp = CamillaClient("127.0.0.1", 1234)
cdsp.connect()
def adjust_volume(direction):
current_volume = cdsp.volume.main_volume()
if current_volume is None:
print("Error: volume not available")
return
volume_change = 1 if direction == "up" else -1
# Clamp volume between -100 and 0
new_volume = max(-100, min(0, current_volume + volume_change))
cdsp.volume.set_main_volume(new_volume)
print(f"Volume set to {new_volume}")
async def main():
device = evdev.InputDevice(MOUSE_PATH)
async for event in device.async_read_loop():
# Listen for relative wheel events (e.g., mouse wheel or similar)
if event.type == evdev.ecodes.EV_REL and event.code == evdev.ecodes.REL_WHEEL:
if event.value > 0:
adjust_volume("up")
adjust_volume("down")
if __name__ == "__main__":
asyncio.run(main())
great... perfect and thx for edit my script...
AND: using camillaClient is for sure the better solution compared to my Websocket one 😉
here a complete script , not for mouse but for remote. i have simplified for use with mouse... https://www.audiosciencereview.com/...mdsimon2’s-implementation.52818/#post-2317807
HaHa...
It seems, you have "a little bit more" experience with scripting 😉
So still a lot things i have to learn 😉
- PC Based
- CamillaDSP - Cross-platform IIR and FIR engine for crossovers, room correction etc
