ERROR:root:CamillaDSP runs without state file and is unable to persistently store config file path
My best guess is that CDSP are started without the statefile argument -s
Example from rep posted previous
/usr/bin/camilladsp -s /home/pi/camilladsp/statefile.yml -o /home/pi/camilladsp/
Thanks again @DEQ+TheEnd , -s argument helped.
Now I'll need to figure out what changes I need in my camilladsp configuration file, because right now I am specifying the port number on the command line. I need to set camilladsp defaults, not just camillagui defaults.
Sry... i got the config wrong, therefore it would not work with Bass/Treble control.
Working fine!
Jesper.
How do you make the camilla gui bass and treble sliders work? ...The thread is a little old, but I started with camilla and I'm a beginner...
If I remember well, you have to create two filters and name them Bass and Treble. The names are case sensitive
Hello, i have setup this week an nice Raspberry 5 with CamillaDSP and MOTU Ultralite mk5
And use Logitech Music Server on it with an squeezelite Player also on that RPI5 with UBUNTU 23.1.
For now runs only as an Stereo Streaming device with an 2x3Way Setup.
Also REW is on that RPI for measuring and works fine.
Before i run an Najda DSP and it was ok but now it sounds so much better 😉
But i ordered alreay an HDMI (1.4) to I2S Board to connect it also to that RPI5 Board.
I want to Setup an 5.1 or 7.1 Full aktiv System and ask me, how i could group all that IN and OUT-put Channels on CamillaDSP GUI for an better Workflow.
I made an Drawing how i think it would be good but im not sure how to deal with and is CamillDSP GUI capabel to doing it.
I read there is an Group possability but not sure how.
The Most Problem i see, is to add the roomcompensation Speaker wise instead of doing it for each Chassis one by one thats lot of Chassis (7.1)
And let say you need an PEQ between Woofer and Midwoofer you must place this PEQ to both Chassis right?
Any ideas? Sugestions?
Hej!
My system stopped working after a windows update. My RME digiface usb device configuration was lost after the update.
Now when I have reinstalled the DIgiface I'm getting the following error message from camilla.
I'm using an old configuration file that was working before.
Any suggestions on what might cause this?
C:\Users\46702\camilladsp>camilladsp 2basara.yml
2024-02-28 19:16:23.697972 INFO [src/bin.rs:711] CamillaDSP version 1.0.3
2024-02-28 19:16:23.698114 INFO [src/bin.rs:712] Running on windows, x86_64
2024-02-28 19:16:23.731595 ERROR [src/bin.rs:344] Playback error: Playback error: Playback device doesn't support format:
WaveFormat {
nAvgBytesPerSec: 1411200,
cbSize: 22,
nBlockAlign: 32,
wBitsPerSample: 32,
nSamplesPerSec: 44100,
wFormatTag: 65534,
wValidBitsPerSample: 32,
SubFormat: 00000003-0000-0010-8000-00AA00389B71,
nChannel: 8,
dwChannelMask: 255,
Closest match is:
WaveFormat {
cbSize: 22,
nBlockAlign: 32,
wBitsPerSample: 32,
wFormatTag: 65534,
nChannel: 8,
dwChannelMask: 1599,
WaveFormat {
cbSize: 22,
nBlockAlign: 32,
wBitsPerSample: 32,
wFormatTag: 65534,
nChannel: 8,
dwChannelMask: 255,
Closest match is:
WaveFormat {
cbSize: 22,
nBlockAlign: 32,
wBitsPerSample: 32,
wFormatTag: 65534,
nChannel: 8,
The channel mask looks strange. 255 means that the eight first channels are used. 1599 means the first six are used, then the next three are not, and then the following two are used.
Unfortunately Wasapi doesn't provide any way to query for supported channel maps, so most applications try with a bunch of common ones to try to find something usable. Sometimes trying to use a format that isn't supported gives a usable suggestion for an alternative format.
In this case it worked and Wasapi provided a nearest match that only differs in the channel mask. Using this suggestion might work, that's something I could try implementing.
Hej!
WaveFormat {
cbSize: 22,
nBlockAlign: 32,
wBitsPerSample: 32,
wFormatTag: 65534,
nChannel: 8,
dwChannelMask: 255,
Closest match is:
WaveFormat {
cbSize: 22,
nBlockAlign: 32,
wBitsPerSample: 32,
wFormatTag: 65534,
nChannel: 8,
The difference is in dwChannelMask, 255 vs 1599. See this thread -> https://www.audiosciencereview.com/forum/index.php?threads/camilladsp-and-rme-interfaces.35838/.
Michael
Henrik, actually for 8ch the chmask 1599 (as implemented in Portaudio) is much more common than the first 8 bits in wasapi-rs. I had to make Portaudio formats preferred in the wasapi java connector for REW https://github.com/pavhofman/csjsound-wasapi/blob/main/src/formats.rs#L120
Compulsory channel mask in the windows audio format is a major PITA. This is actually the first time I see a device making a suggestion for the correct channel mask.
Thanks! This helped me. there is a setting in sound control on sound enhancements. This must to be disabled. It seems that this was changed during the windows update…Thank you microsoft for steeling 5 hours of my life :-(The difference is in dwChannelMask, 255 vs 1599. See this thread -> https://www.audiosciencereview.com/forum/index.php?threads/camilladsp-and-rme-interfaces.35838/.
Michael
Now it’s working!
Thanks all for your support!
Don't bother unless you have an issue! The new versions (2.0.2 and 2.0.3) only fixes a few very specific bugs. There are no other changes.Time to upgrade... is there a Mac installer script please?
There will be a new gui very soon, that will come with a new installer.
Ok thanks, I will add 1599!Henrik, actually for 8ch the chmask 1599 (as implemented in Portaudio) is much more common than the first 8 bits in wasapi-rs. I had to make Portaudio formats preferred in the wasapi java connector for REW https://github.com/pavhofman/csjsound-wasapi/blob/main/src/formats.rs#L120
I also haven't seen it before. Wasapi really lacks a way to ask for "don't know and don't care" as channel mask.Compulsory channel mask in the windows audio format is a major PITA. This is actually the first time I see a device making a suggestion for the correct channel mask.
The channel masks are complete mess. E.g. Audio Apollo Solo USB requires chmask 0 for capture and non-zero chmask for playback. Even Portaudio will not capture from that device because it does not try chmask zero.Ok thanks, I will add 1599!
Hmm I already made a method in the wasapi binding for trying various channel masks, including this 1599. But I didn't finish the job, CamillaDSP doesn't use it. I'll fix that in the next version.
Maybe a chmask config parameter would be useful too. The testing loops make take precious time at startup which may affect overall latency of the chain. Some Win7 have the isFormatSupported checks broken, taking progressively longer time https://www.avnirvana.com/threads/v5-20-12-v5-20-13-release.11029/page-2#post-85053
EDIT: removed the references to linux controls 🙂
Maybe, but I try to keep the number of config parameters down. Let's try with the approach of trying all the common ones first.Maybe a chmask config parameter would be useful too.
This should not cause any issue here. Sample rate, number of channels and sample format are all fixed, so the testing loop will only need to go through a handful of channel masks.The testing loops make take precious time at startup which may affect overall latency of the chain. Some Win7 have the isFormatSupported checks broken
- PC Based
- CamillaDSP - Cross-platform IIR and FIR engine for crossovers, room correction etc
