I like a PA driver(mid woofer) whose parameters and price meet my specifications. I want to use it for home hi-fi use but there is one factor which I am not so familar with.
Those which expertise in the construction of woofer please comment.
The spec. for the driver which is made my P-Audio, it says:
Materials of construction
APS ferrite. Pressed steel chassis, Paper cone, Plasticised cloth(linen) cone edge. Solid composition paper dust cap, 2" round copper wire voice coil, Kapton former.
The spec. is pretty std even with driver for HIFI use except for linen cone edge. Does this affect the sound/performance of the driver in anyway?
Any comments anyone?
thanks
thanks
It probably means surround. Cloth surrounds are common and they usually have some form of doping to make them airtight.ttan98 said:
Cloth accordion pleated suspension surrounds were actually pretty common at one time. Though they were most often found in Acoustic Suspension or speakers meant for sealed cabinets.
I think speakers have all switched to molded foam suspension surround because they are easy to make, cheap to buy, and do a good job. But that's nothing against the cloth surrounds.
I don't think it is any thing to be concerned about if the other specs fit your needs.
Steve/bluewizard
Steve/bluewizard
BlueWizard said:Cloth accordion pleated suspension surrounds were actually pretty common at one time
They still are in the pro world as they are much more robust than the other options. 😉
And many of these are fantastic options for home systems especially if you don't like those dinky little headphone sized 'audiophile' drivers.......pinkmouse said:They still are in the pro world as they are much more robust than the other options. 😉
Brett said:especially if you don't like those dinky little headphone sized 'audiophile' drivers.......
- Calling Driver Expert to comment
