Bybee Fraud Protection
When I first tested the Bybee AC modules, I should have been biased AGAINST hearing any difference. I first measured them with the equipment I had available and could not find any reason they should work. They just happened to work in the test I ran.
It's not conscious bias that you are dealing with. If it was, you could make anything sound perfect by just thinking that it sounds perfect.
Bias is unconscious, which is why when doing psychological testing, people take measures to ensure that unconscious bias does not void their results. In psycho-acoustics ( what audiophiles don't think matters ) that means blind and level matched.
Were your tests of that nature or did you just plug it in a check it out?
I always just plug it in and check it out. That is how I find what it sounds like. However, I use the best sources (analog) with material that I know well, and use the most direct coupled approach to electrostatic headphones that I can afford. Only then can I hear subtle differences relatively clearly, rising above guessing.
So no confirmation by blind testing...
Also you said you measured them and couldn't find any reason why they worked....
Well, that was when I made an effort to talk to Jack Bybee and asked him how they worked. He gave me some measurements both showing both WHY I could not measure anything useful, (or anybody else doing similar tests), and an ACTUAL measurement with a specific measuring instrument that I do not possess, but the results of the measurement show a difference in noise on a power line. It is not a whole lot of difference, BUT it is a measurable, and most likely, repeatable measurement, using what Jack Bybee used to make these measurements.
The fact that I HEARD the difference, working alone, not even knowing Jack Bybee, in my own facility with my listening equipment, still gives me the knowledge that these devices are not what many here conjecture, and they can change audio quality for the better, in many cases, although they sometimes make it worse (where did that come from?) in some listening situations with some audio equipment.
Magic measuring machines that us common people cant access?
What was he measuring, how was he measuring it, a bit more factual information instead of trying to ne mystical, this is engineering after all...
The more I look around at some of the stuff being peddled to Audiophiles the more disgusted I am becoming with a large factor of the high end esoteric audio companies, a lot are trading in lies and untruths.
Marce, I think this is the info that you want:
