wish u actualy said something worth learning.....That's good, it seems you start to learn.
kisses, byeee
I've already mentioned several things you need to learn. I was honestly surprised you still need to learn reading. Start with that one first.
That was my suspicion and the reason that I mentioned to invest in a solid protection circuit, matched to the loudspeaker system. Imho the only thing that can keep you away from frequently reconing and exchanging diaphragms.the volenteers get a little out of hand and crank up the juice to insane levels.
And although you didn’t mention seating area dimensions and said something about speaker placement, the obvious solution stays getting the tops up above the audience. But you likely know that.
so no pics...from your few comments on the boxes i'd venture they're quite similar to a JBL srx cabs.
Sorry about that got caught up setting stuff up.... but yea its basically same in all the dual subs boxes with 15"s and a horn (1 round horn not the rectanglar ones) ... pics would have to be taken of those old boxes later tonight or tomorrow if u still really need themso no pics...from your few comments on the boxes i'd venture they're quite similar to a JBL srx cabs.
Oh yea thats basically all i been asking for really lol , either get it custom or if the sell em which one to get or what parts to get to custom it... take away all the measurements of room etc and just focus on speaker and amp numbers to not fry things.....That was my suspicion and the reason that I mentioned to invest in a solid protection circuit, matched to the loudspeaker system. Imho the only thing that can keep you away from frequently reconing and exchanging diaphragms.
yea i know that for sure, next sanctuary we going for line array at the top.. but i have these sitting untop of subs so they are still a bit high up in terms of above crowd lolAnd although you didn’t mention seating area dimensions and said something about speaker placement, the obvious solution stays getting the tops up above the audience. But you likely know that.
well hoping to see just what your trying to "reload" in order to make more specific recommendations on drivers.
what are they made out of? do they have proper construction for flying?
measurements of size to determine box volume would be a good start, and a bit more info on the horn flare if possible.
- Building top cabs
