I do not know what a CLD construction is.
We did discuss that, but it has advantages (theoretical) and disadvantages (theoretical).
In my opinion a separate mid range unit decoupled form LF will not benefit from the sheer mass of the total enclosure.
The best part of the original design (see link above) is its midrange. I think that next to great components it is the stability and mass of the total enclosure that helped making this stand out. The total speaker will also become larger. I know benefit from the space behind the midrange to be added to the LF volume.
CLD is constrained layer damping, arguably the best way to dampen panel resonances. I won't repeat what already has been written quite a few times. But take it that a small midrange unit with adequately damped separate enclosure walls is superior to integrating the midrange in the main enclosure. Main enclosure equals big panels equals much sound contribution from panel resonances. Just my 2ct.
why dont you make something like this
for the midrange and then the the "flower" cut out? Is such a big baffle for the midrange necessary? Mids would then even have more Air to breath.
Ahhhh yes I have looked into that a few times, and I have heard some nice demo's that proved it worked, but these were all fairly light constructions.
This speaker will weigh around 150kg
What you don't see in these renders is that we will use a rubber seal between aluminum and internal MDF structure (mainly to cope with stress on the rods if part of the structure expands/contracts more than others. The angled midplane that separates mid from LF will be strengthened and all panels will get lead bitumen layers and of course several forms of absorption layers like technocell.
In my experience mass will be equally or better than having a seperate fairly light structure holding mid.
And from the inside outward on the sides. Technocell, Lead bitumen, 15mm MDF, 13mm HDF, 18mm Walnut
I kind of do, but I leave more mass in the midrange section that helps dampening resonances. The fairly thin part of your midrange section is more prone to vibrationwhy dont you make something like this View attachment 1329082
I agree the 10 rods have more than enough stiffness and strength for this application. My concern is the opposite... there is a risk of over-tightening the threaded connections and compressing the wood structure to failure. With 10 bolts, it would be very possible. Are you planning to use a torque wrench to control the level of pre-load applied to the rods? I would recommend that.The length/diameter relationship makes this look flimsy, but with 10 pieces M8 bolts of normal length you probably wouldn't mention it. One M8 bolt can handle 2200 kg, that is 22.000 kg for 10 bolts. Sounds fine to me.
Another advantage to this design is being able to alter the preload on any given rod. This allows deal with cabinet resonances by tuning the cabinet stiffness to get the least possible resonance signature. Overall, it is a very robust and impressive cabinet design.
It is a very high-end absorption material. Self adhesive. And gives better absorption than the typical black egg box foam@PSchut What was technocell again? i think i heard of it but can't remember 🫠
No it is absolutely fine, and if you go back to my original design (linked above) I did the same for an even larger design. The length/diameter relationship makes this look flimsy, but with 10 pieces M8 bolts of normal length you probably wouldn't mention it. One M8 bolt can handle 2200 kg, that is 22.000 kg for 10 bolts. Sounds fine to me.
The resonance remark is indeed something I am aware of, and solved in the Original design on a few places by placing a rubber piece between the housing and the rod. In 8 of the 10 places the rods pas a wall and that helps dampening it where I will have to apply a silicone type kit to close the hole.
Oh and I stole the idea from the original KEF reference introduced 8-10 years ago, not Magico. In the latest iteration of that design they removed the rods again.
Why do we need vertical bracing? I am not afraid of a resonance in these bracings,
These bracings have only one function, and that is to make sure the large side and in lesser degree front panels do not vibrate.
The front and back are extremely rigid and are joined together with the 10 steel rods.
The top and bottom also have some extra support.
So what they need to do is dampen predominantly the sidepanles that are constructed of 15mm MDF (550kg/m3) the 13mm HDF (1100kg/m3) and then 18mm solid Walnut (750kg/m3)
Also a rectangular hole leaves more horizontal wood as the connecting interfaces and are therefor stronger than round holes when you use the same surface size of the hole. And you need to make sure that the holes in the braces are open enough to make sure the speakers do not see a smaller volume because the connecting volume is limited by the holes connecting them. So my rule is to approach the volume of the cone area of the two woofers and then square holes leve more leave more connecting surfaces then round do.
Nice Project.
I disagree rectangular bracing is stronger than round hole. Example is colosseum or bridges. Without arch those buildings would collapse. Simple as that.
You can remove quite some wood in round hole and the bracing would still be rather strong. It you don’t, bracing is VERY strong even when twisting.
I believe general advise/rule of thumb is minimum 50 % of membrane of driver to let driver breathes through bracing.
General advice: MDF is bad for bracing (and generally main quality is that it is cheap) and I suggest you use high quality ply.
If you are open to more suggestion, you could think of using WG. I think even cheaper tweeter in optimized WG runs corners with non-WG tweeter.
I highly suggest you experiment with clean carted wool especially in midrange.
Next we have mounting of drivers, where I suggest experimenting with midrange driver mounted from behind. A lot of companies do that nowadays, even cheaper speakers. It looks great and from sim (can’t find post), optimized shape has better dispersion then mounting driver flush. In both scenarios corners were rounded. Not so easy to build.
The baffle thickness was 55mm. The thin part was 25mm thick actually, 30mm thick alu wg was mounted above midrange. Definitely not limiting factor in any way.I kind of do, but I leave more mass in the midrange section that helps dampening resonances. The fairly thin part of your midrange section is more prone to vibration
Hi Rokytheman,Nice Project.
Thanks for your reply. I share this with you guys not just to show off 🙂 but to be challenged and get feedback like this.
You have a point here but I like to still argue it. An arc was used in ancient history to help building a span between two pillars as the arc kind of supports itself during the construction.
But here we want to reduce vibration (and I can tell you my previous design is dead). To me, just using logic as an electrical engineer, the function of the bracing is connecting the opposite walls with a beam. Ideally a few beams as every time you half the width of the panel it resonance frequency doubles but half’s in amplitude. As individual beams are unpractical to mount we use panels with holes. The strength of the beam wil be linear to intersection area of that beam. My logic tells me that round holes with the same breathing area then square ones will produce thinner beams.
My theory is followed by Magico and the Kef Reference 5 (where I stole the M8 rods idea from)
I understand that for a DIY project with no CNC round holes are more practical as you can see on the extremely informative pages of Troels Gravesen.
Oh and most of the internal bracing is constructed with 1100kg/m3 HDF (Finsa Compac Plus)
I am sorry that I have to disagree on another point 50% breathing area is not enough as I had a secondary impedance bump in a previous design because of the limited area in a two bass speaker design.
The waveguide subject also came up. But this tweeter is so nice in a flush mounted curved baffle spanned with a fairly soft leatherette that this was a no brainer to copy from the original design.
Yesssss long hair wool in the midrange as filler
We also looked at rear mounting the drivers. It sure looks good. The problem is the relative thin area you have to mount the units into. Again plain logic tells me that this ruins the whole stiffness of the baffle. That is why the thinnest part of the baffle is still 15 mm but where the mounting screws are it is 40mm. Having units mounted behind a 15mm baffle will definitely cause diffraction errors. A thinner residual thickness will cause mounting issues. Or the need for strange clamping hardware like Magico uses. And these clamps interfere with the minimum inside space I have to make the enclosure as narrow as possible.
These are all compromises in the end and personal preference and practicalities dictate the choices I made.
But the challenges, disagreements and tips are very much appreciated.
Talking about compromises. When we started I was confident it needed to be a passive design.
This has two major challenges.
First the spl of an 8"driver that produces still a decent LF (30Hz) will not be loud. The two underhung midrange speakers can not be ordered with a higher Re as I used in the previous design, so they needed to be tempered quite severe.
Second, the big LCR resonance filter that is needed to remove the second impedance peak is plain ugly and if done well not cheap.
Both problems are solved with the Hypex module, I would hope that the sound quality (that is pretty decent of an nCore Hypex module) will not interfere with the high quality analog amp my fellow builder and I use. My friend uses a 50W tube amp so he will gain a lot in dynamics. I use a fairly beefy 400W discrete amp that will be a bit overkill for just mid/hf but the impedance of the mid/hf section will drop below 3 ohm so it won't hurt having some reserve power.
As a bonus you will get some dsp power to fight some room resonances if needed
So a compromise that is turned into what I hope is a virtue of the new design
I do not quite see why stiffness of the baffle would be better regarding midrange mounting. What is the explanation behind this?The problem is the relative thin area you have to mount the units into. Again plain logic tells me that this ruins the whole stiffness of the baffle.
Hi Markbakk,
My current speakers (see introduction) are still absolutely fantastic still after over 7 years since I finished them.
I think I used good drivers tweaked a nice filter with top filter components.
Every time I take the time to sit down and want to enjoy some music the speakers perform from the first note and magic happens.
Next to all the virtues I list above I think it is the sheer mass (~150kg) and stiffness of the enclosure that makes it stand out.
To me logic tells me that only the cones and dome of the speaker drivers are allowed to move and produce sound, the rest of the enclosure should not. So you need stiffness and mass both in order to prevent the moving mass and air pressure triggering any resonance. The slightest movement of a side wall having 10 times the cone area will color the sound.
I am not saying that a well constructed 2-way bookshelf speaker cannot sound great, but it will be outperformed by a stiff heavy version using the same components.
That is also why I prefer a single rigid enclosure over multiple separated ones decoupled or coupled.
I hope this explains the concept I am using (that is of course not the only way to get good sound)
Hi Forum,
A small update on the project.
Not a lot has changed but quite some small little details and corrections needed to be made.
The internal angled panel for mid has been replaced by 3 panels to help with the construction and entrance of the mid reflex tube. Also all internal bracing is now made out of the 13mm HD instead of a mix as we needed an extra sheet of that material anyway.
I found a nice over the top midrange reflex port full aluminum Flange:
And I think I will try to glue the walnut sidepanels to the enclosure with 3mm spacers and than use a flexible kit to allow for expansion and contraction of the wood inspired by a teak boat deck
The aluminum base has been made slightly less organic to reduce CMC cost.
Some other improvements/features are: two banana plugs to make it easy to measure the voltage from the plate amp to the speaker (with respect to the high level input) and a small switch that we can use to have a small light behind the logo as an indication the amp is on, or hide that light (TBD)
The speaker terminal holes are now standard for a lot of brands of terminals including WBT and Dayton.
The first woodworking will start mid August with CNC work of all internal parts, and then we will also order the metal parts (Front, Back, Amp Plate and base)
More to follow soon.
Nice.
Will be nice to know how you like the Fusion amps. To my knowledge very few actually describe How they ‘sound’ compared to for example passive and good amp. To my memory, in the Hypex Fusion thread on this forum, more than 100 Pages, there was never a deep dive how they actually sounded.
Well I listened to the Mola Mola poweramp. One of the best class D designs from a few years back using the same technology NCore from Hypex as is used in this design.
Quite expensive, but for a very decent price you can build an NC500 design. My fellow builder used to have that amp as well.
At first they are very impressive, fast, powerfull. But in the end cannot compete with a top analog discrete design or good Tube amp. In this design it wil be used below 250 Hz and I think these amps are absolutely great for doing that. You will get nice control of the LF units as no passive filter components are used. so no interaction with the large (>5mH) inductor and the resonance of the speaker. Room correction possibilities with the DSP is an added bonus and the DSP is not covering the whole frequency range but only the LF part.
Coming back to your question: I do not think you will get a top performance with these amps if used full range. The DSP with fairly straightforward AD and DA conversion will be limiting factor. And if you just spend big bucks to a >15k DA converter for your Tidal account it sounds wrong to me to then let it pass full range to this design with possible a 15 dollar AD > DSP > DA structure. The non-processing NC500 is a serious high end contender though
Anything is better than egg box foam.It is a very high-end absorption material. Self adhesive. And gives better absorption than the typical black egg box foam
- Building the best 3-way (NOT) full range speaker in the world
