Building a cheap 250W dummy load
Hey dudes.
I was planning on making a cheapo dummy load like following:
Two 3.9 ohm 50W wire wound resistors in series, installed on a large heat sink taken from a scrapped 100W mono amplifier.
This would make a nice 8 ohm 100 W dummy load, I think.
I'm planning to make two sets, and connect them in parallel, for a 200W 4 ohm dummy load.
But here's the kicker... I need 250 W. So I was thinking of submerging the bottom halves of the heatsinks in water. No risk of shorts or anything like that.
What do you think? Could it work?
I'd use mineral oil contained inside a gallon paint can.
at least that was what Heathkit used to offer in their 'Cantenna' RF load.
I'm pretty sure you can easily purchase the can at a paint store and add your own jacks.
I think water is problematic when it bubbles near the hot surface.
Hot water tank heating elements
And if using commercial resistors, why are we using 15 ohm and 3.9 ohm and "coming close" when dead on 8 ohm and 4 ohm resistors are available off the shelf and cheap. For example, 8 ohm 1% 50w heatsink body with mounting tabs:
http://www.mouser.com/ProductDetail...Nd0dY0KymzjQZdWkJqzrBWtgCUMzOAeNATfj4sAIvqQ==
I totally agree which is why I proposed the 25w 8ohm anodized aluminum body resistors with tabs in post 3. The mouser ones are well priced - a lot less than I seem to recall another major brand one.
If you want cheap, the large (8in) stove element is about 27 ohms. Three of those in parallel and you don't need to mess with water cooling or heat sinks. Make a tea while you're testing your amp too. People throw out stoves all the time.
There are guys building PCs with the entire motherboard submerged in mineral oil.
Forget liquid cooling; give your PC an oil bath | PCWorld
Soak Your PC in Mineral Oil: Puget Systems Announces DIY Aquarium Cooling
