Building a battery compartment
I'm building a headphone amp, but I'd like to build in a battery compartment so I don't need to open up the entire casing each time I have to replace the battery. I've searched for a battery holder with cover, but haven't been able to find one anywhere.
Any tips on constructing a battery compartment?
NiMH or Nicad batteries are dead easy to use... one resistor and a supply (charger) higher than the battery voltage is all that's needed. If your using PP3 and AA then thats two resistors 😉
That assumes the batteries are "disconnected" when the H/phone amp is switched off.
Rose & Bopla:
