Building a 1000W @ 8ohms class D amplifier from zero
I think there is error here, since lower one has 12v, I assume other will have it too
Hello Luka,
But it should work with 5v also.
From IRF data sheet Vdd (logic supply voltage) max value is Vss + 25V.
Hope that I am right because I started to try to develop SMD PCB version for it :p
Attached is the ongoing PCB version. It still need the output filter stage, feedback, supply filtering, top and bottom ground planes and a buffer at the input because i think i have to drive it with a differential op-amp with one out 180 Degree shifted from the other.
Please correct me is i am wrong. I am new kind of new in this field.
Best Regards,
Savu Silviu
Greetings :)
First, it should be noted that I am n00b, therefore nobody has to point out how stupid I am, because I previously knew that. :p
Second, I have a college education in electronics, however though it went over some theories of amplifiers, no classes concentrated specifically on that.
Now, here is my subject:
I have recently purchased two speakers.
They are simply single drivers, I have yet to build a box
The frequency range is 22Hz ~ 4kHz
Resonance is 22Hz
RMS power is 1000 watt, per speaker
Peak is 2000 watt, per speaker
Size is 21" diameter
They are each 8 ohms :att'n:
I am having a lot of trouble finding a production amplifier that can supply 1000w RMS per channel at 8 ohms and 2000w max at 8 ohms. Most amps barely make 1000w RMS at 2 ohms. Of course that doesn't work with an 8 ohm load. These drivers being 8 ohms is what makes this a bit more complicated. I have two of these speakers, therefore a two channel amp needs 1000w RMS per channel at 8 ohms. If a production amp exists for this particular speakers, I have not yet found it, but I did find this thread in google search, because it mentions 1000w into 8 ohms. I have read this thread from first to last post, but still not sure if the designs posted here will fit this application. I saw some posts that do not believe 8 ohm 1000w speakers exist... but they do, I own two of them. I also read some about the frequency, if I understand correctly, these amps do not go down to 22Hz? My primary operating frequency range would be between 22Hz~400Hz probably. Is there a design currently good for this application?
Many thanks for help on this subject :D
You can build a class d amp with a few bit and pieces.
Triangle wave generator and input amplifier both going into a comparator.
The output of the comparator is level shifted into an xor gate to phase split the pwm and then put into a IR2113. The output of the 2113 drives a pair of MOSFETs.
Mine worked a treat although for some reason I needed a DC offset adjust on it.
I did not use any feedback, it is totally feedback free.
Sorry but it is very hard to read,
