Pioneer v210 = 90w /2 pair mt-100.
Power supply 400VA + 10Kuf X 2 for both channels.
Not bad , but it seems to match the 3-way speakers that were
marketed with it.
OS
marketed with it.
OS
So those speakers which survived a 90W/ch amp are now going to be used with a 350W/ch amplifier 😱
Good luck with that 🙄
Like cumbb postet, to real listen music this is a good example, wich no cost much and canNot standing speaker = compact = good/better than a standing,-)
handle more power you can normal use in home.
Strassacker: Loudspeaker, Coaxial speakers, Driver, Tweeter, Mids, Woofer, Subwoofer, Components
choose: Mission- CP-164- show kits to this chassis- Aras- 89db,4Ohm with HT- Kalotte:
Seas H1025 No Ferro 900, is the same.
So you have a basic real good speaker, for money!
Like Andrew:I really doubt that 10" speaker can take 350W.
That's it. Don't believe any commercial Nonsens!
In that power ratio it is a specialized speaker for Subwoofer use only or a real powerfull
PA in midtone section, up to bass 150Hz or so.
I have in use a subwoofer Morel UW1058 in 50l closed cabinet, that needs a real kick in
a.... 400W class D Subamp IMG Stage Line SAM300D to go on work. You can look.
http://www.lautsprechershop.de/pdf/morel/chassis/morel_uw_1058.pdf
Now you have a set to shaking the house!
The newest, Andrews know's is abetir & valery VHex- creation, i also would build it.
An other Idea is APEX FX-8, with sonal kunal 50x50mm Boards, you can order with Gerber Files by seeedstudio- 10$ for 10 boards.
Go to read the last sides in thread.
If you have some friends, make a gift with left over boards, so they also can enjoi it.
So go on. DIY is great!
Regards Bangla.
If you have
Regards Bangla.
If you have
thanks everyone for the nice comment. i have already built apex ax14 and perkutut 150 by Bimo. its open my mind, thats i dont need big power amp like 350watt. the apex ax14 a nice sound. i like it, sounds like live music.
Hallo ardi79.
Great to read you have build and running Amps from two Experts here. Enjoy Music.
I also on the way to build my first Apex, finally, after long time follow the Thread, i like AX11- and actually there is LatFet FX-8..... and variants, so i will start the FX-8.
For a right working budget Speaker you can look also strassacker again, for example.
CT 285 (FAST) Floorstanding as in K+T 3/2016 , and same chassis, this one:
CT 273, Shelf speaker as in K+T 4/2014 - this one works nearly one point source,
Fullrange Speaker.
It is all a part of combine good partnership between Speaker and Amplifier and by finding enjoying listen to that.
That is also my way of finding.
Regards Bangla 50+
