build NEW AV800 / AV1000 MOSFET AMP IRFP240 IRFP9240
dear all.
happy holi when i press and after removing paper the image destroy on pcb clad board so i want to use toner transfer from uv lamp .plz tell me the wattage and size of uv lamp .because i heard that that image are very clear so the pcb will also clear.if you finish 1000w amplifier plz send me pcb also,,thanking you.masood
hey friends i am going to make amplifier for subwoofer i need good low pass filter for subwoofer and need suggestions for what amplifer to use for this speakers
today i started my amp....
1) print file laser printer.
2) clean pcb board and paper to pcb use iron box with 10min over all press.
3) move to water....
4) mix acid and water to basin..
5) light touch pcb to mixed acid and clean with water and remove paper and touch with cloth and apply nail polish to use some print correction after etching...
6) and mixed acid etching...
7) finish pcb board..
next drilling and component mounting...
dear ashok,
when i do this process and peeling the image the ink transfer has not gone well.so please give me any other idea by which i can get sharp image on copper board.thanking u yours ever masood
