Brian,
What are Ic4, Ic5?
IC4-IC6 are analog switches for switching between S/PDIF and PCM/DSD.
Brian: The switching, will it be simlar to the 4-spdif board that you short to pads of the IP_S, and if "programmed" with external controller, what kind of command would you need to send to "switch", just a 5v(to two bits in different orders?)
You set one of the pins to logic low (gnd).
Actually You would simply either not install the clock trident, or switch out power from it. There is no ferrite in front of the tridents any more.
My solution if you think you will ever switch between Asynch and Synch is to use a socket for the clock Trident. Or power that trident separately from a switch (by not connecting the input pin to the Buffalo)
Most people will simply pick one and run with it. 🙂
I don't believe that's a good solution, to leave the output of XO connected on the clock line, even with the supply power off. The XO's output is not designed for tristate operation and is not high impedance.
Sorry but you are incorrect.
As Brian says, when the clock is not powered it's output is in a high impedance state. I consulted Crystek and tested it myself to be certain.
BTW, people have been doing this with BII and BIII for years. 🙂
HI, Roender, maybe a different approach other than endlessly questioning the efforts of the designers of the Buffalo DAC would be to apply your understanding to the creation of your own design and demonstrate the effectiveness of your ideas. This would certainly benefit the entire DIY community in many ways, both by providing us options and by ending this banter. In the mean time, Russ, how can I order this DAC? I would love to place my order today. I checked your website but dont see it listed
They will go on sale in the next week or two. I will be creating a separate web page for the se version shortly.
GT87928, calm down, please 🙂
I have nothing against BIII DAC as it is now implemented, nor his designers ... just rising some legitimate technical questions.
Regarding my contribution, search yourself trough the forum ...
It's all good. These are the same questions we asked ourselves during the discovery/design phases.
Thanks...
Russ and Brian! The B-III SE is exactly what I have been looking for. The advantages of the B-II and B-III, is a simpler package, and with u.fl for connecting I2S including MC. This will be perfect for my next (definitive?) build.
Healthy curiosity, that's cool and I certainly can appreciate it. 🙂 There is certainly a sentiment among those closest to me that I should show more caution and ask more questions and less enthusiasm when I become intrigued with something new. It just seemed that there was a reluctance to accept their design and it was bogging down the conversation. If I seemed 'excited' I offer an apology, I truly was not. Just trying to move the conversation forward, that's all. 🙂
I really appreciate all you folks.
I have learned a lot from people who have been critical. I don't mind a bit as long as folks are trying to be helpful.
Roender's question was valid and worth answering.
I also appreciate your support GT87928. It can be very hard to judge intent with only the written word. 🙂
Thanks!
Russ
Thanks!
Russ
I am glad to hear that.
Brian and I have been thinking this really hits the sweet spot for many builders. A great balance - you get all the performance, but in a simpler to configure package with simple intuitive input interfaces.
I can't wait to see how your rig turns out. You have done great stuff in the past.
Cheers!
Russ
Dear fellows,
I have two questions:
Question A
Suppose that I would want TPA B-III SE to have two sources:
1) TPA USB to i2s converter; and,
2) External transport with both legs of TPA teleporter.
Is it possible to connect both sources with u.fl?
Question B
Suppose I want to use the TPA USB to i2s master clock while playing USB material and the B-III SE master clock while playing the transport material.
Is it also possible? Do I need some kind of switch to power on/off B-III crystal?
Sorry if those questions are simple...
Question A
Question B
For question A, I have some good news...
The OTTO-2 now has optional pads for u.fl connections!
The board will ship as before, but there will a new option for a (12) u.fl connectors to be added to the kit (user-mounted). I should have the web page updated today.
Any update?Yes - we are just ordering those boards in the next few days.
The Buffalo-IIISE (Stereo Edition) 2-Channel DAC
U.FL for external MCK is pre-mounted. A four=pack of U.FL connectors is available separately for those who want them for digital inputs.
- More Vendors...
- Twisted Pear
- Buffalo III - SE
