budget class d amp for low sensitive speakers
I think i would limited it to a 32 volt power adapter because i don't want the amp to get to hot when playing loud music,it's already very hot in europe , denmark and it does get a little hot mabye 35c but not as hot as my tube buffer,preamp.
Im not in any hurry to get a 32 volt power adapter but i like to know what it does my amp,system and if it gets to hot for my taste (amp when playing loud)
On the amp it says 12-24 volt mabye i just have to accept that 24 volt is max
One customer comment:
"However, here's my one gripe as an EE that is no stranger to questioning specifications. It's disingenuous to say that this amp could deliver 160W+160W RMS. That is indeed the nominal datasheet spec for the TDA7498E, but it's only achievable under the following conditions: Vcc=36V, RL=4 Ohm, and THD=10%. The power supply shipped with this unit is only 24V, and the internal electrolytic caps are only rated to 35V. Assuming we want to stick to <1% THD with our 24V power supply and stock caps, Figure 4 in the datasheet tells us that we're able to source 60W+60W RMS into a 4 Ohm load. For 0.1% THD this figure is reduced slightly. 60W per channel is very much loud enough for my application, but it may matter to you!"
With that in mind, your amp is not high power, but average.
you can argue if 2x160 watt is not high power for low sensitive speakers, it can make them play loud, for speakers with high sensitivity like some klipsch and zo audio speakers it's gonna be party level in a big room.
My full sized hif amp is indeed a 2x160 watt amp dynamicallly or peak power in 8 ohm, lowered by 10 db to gain,level match it to my turntable.
It's still loud but a different loud (or sound if you will) when comparing a/b to class d
I know class d is rated at higher thd, therefor i wanted something above the usually 2x50 watt in 4ohm
My mini system for my tv is actually Class d (nad c717) and it also does a great job where it too has it's forces in the midrange with a little bright'ish top
About the supply:
Better than the 24 volt 4.5 amp that comes with the unit?
Math says that 24*4.5=108W so that´s the maximum DC power supply can give you.
With 85% efficiency (straight from datasheet) that allows for 108*0.85=91.8W RMS TOTAL
Enough for the 2 x 35W RMS I estimated.
Ad also claims:
160W X 2(4 ohms, 20 Hz - 20 kHz, 0.04% THD)
which not even the datasheet, under ideal conditions does.
They speak of 10% distortion.
I also LOVED this bit:
Maybe the earlier supply connector melted or caught fire?
Im in for a fairly powerful class d amp for under €100 or £90 for my low sensitive speakers
So fare i have found a FX-AUDIO FX1002A and a Fosi audio TDA7498E amp within my budget
Some say smsl amp below the FX1002A can have have channel unbalance and hiss
The Fosi amp seem to have gotten som improvements like this over the older version but is it better than the cheaper version of the same amp like the one from breeze audio
The fosi amp only comes with a 24 volt power adapter where the fx audio amp comes with a 32 volt power adapter
hiss and channel unbalance ?
What is the amp to go for ?
Hello,
I just received and tested my TDA7498E class D amp connected it to my computer and my Technics SB-X3 old speakers and played some FLAC and APE music files, some CD quality, other 24-bit Hi-Res and I have to tell that I'm astonished by the sound quality.
I just purchased the most cheap I could find:
60Wx2 TDA7498E Digital Amplifier Board Dual Channel Stereo o Amplifiers Support BTL Mode Mono 220W With Case
60Wx2 TDA7498E Digital Amplifier Board Dual Channel Stereo o Amplifiers Support BTL Mode Mono 220W With Case|Amplifier| - AliExpress
32V 5A Power Supply Adapter Driver Switch DC Converter Dock LED Driver
32V 5A Power Supply Adapter Driver Switch DC Converter Dock LED Driver|Chargers| - AliExpress
1Pcs 5.5x2.1mm Female DC Power Jack Connector Plug Adapter For 5050 3528
1Pcs 5.5x2.1mm Female DC Power Jack Connector Plug Adapter For 5050 3528 Single Color LED Strip Light CCTV Camera|5.5x2.1mm female dc|female dc power connectorconnector for led - AliExpress
For just around 34€ I think that was the best budget amplifier I could find 🙂
