Budget 1.4" driver & waveguide combo
This ME10 clone horn is built very well, thick and non-resonant. I am relieved I wont' have to return the Lase compression driver and horns after initial listening.
Reactions: scholl
And I ordered the Lase horn 10.5x10.5"
Nice thing about that horn is that if the room is small or close to side walls, rotate lens for 60 degrees horizontal……..for home use the 80/90 is really too wide. I’d LOVE to see a 60/40 or even a 50/50 lens for typical 8ft ceilings. JBL for their pro home cinema used to make the Syngergy 1400 which was only around 45 degrees horizontal and that system sounds amazing
Perhaps you like this one as well. It's 40x30° and 46cm deep, thus can be crossed low.
JBL-353250-003 Horn Flare 40x30 PT43-HF_4.jpgJBL-353250-003 Horn Flare 40x30 PT43-HF_7.jpg
