Buchardt crossover question
Hi
Attached photo is the crossover in a Buchardt s300.
I am in no way experienced with crossovers, but it seems pretty wild since it is only a 2-way (crossover point 2600Hz).
However that may not be enough to keep me from trying something on it. A blind hen can also find corn.
So: is it not fair to assume that the 3 sand cast resistors are connected in series? I can find the same sum of values with 2 resistors in the Jantzen superres series, so that might be a start.
Of course I would need to get it out of my own speaker, and I can then verify on the bottom of the board, it would just be nice to hear any comments beforehand ;-)
I believe they've built in some kind of phase correction, which might explain the complexity. I also know they have a signature edition of their s400 model, where the topology to me looks similar, where they have used superres resistors, superior z caps for the tweeter and cross caps for the woofer. And silver wiring.
Thanks a lot for suggestions/input
The section with the pairs of 18µF and .39mH seems to be the allpass network (for the phase correction). But I also don't think you will do any better than with this setup. And since those Buchardt speakers seem well designed to me, I'd hesitate to even change a mounting screw.
There still seems to be popular tweak to swap crossover parts as for trendy high end parts, why is that? I bet very few will hear a difference in a blind listening test, like the sand cast resistors, they might have a higher inductance then metaloxide resistors, but how much will this alter the frequency response and phase?
It's fun to tinker and fiddle. But I'd suggest you pick a speaker with more potential. This already looks good and has good reviews.
If you are serious - get a measuring kit setup so you can see the effect of what you are doing. Sure you can just swap parts and use your ear to simply say do I like it or not... but measurements will help you track in a direction, rather than a random crapshoot
+5000 on having a measurement system.
You can get started pretty cheap - Behringer UMC202HD, ECM8000, mic stand, XLR cable. If you get a couple of 1/4" jack cables and a 100ohm resistor, you can do impedance, too.
Chris
PS - My current speakers use 15 components for a 2-way design. Both drivers needed a lot of work to get them to play nice.
Ja, those Bennics are putting a hurting on my sensibilities too! And who's ever seen a puny 100V rating on a film cap??
Btw, did you know that a hen can be taught to never lose at tic-tac-toe (aka naughts and crosses)? But not a blind hen...
Serious question: do you have an amplifier capable of 100V peak output?
Further, do you have any drivers that will withstand that sort of input?
I do, but I also run a business involving PA systems.
For domestic use, 100V caps will be perfectly fine.
Chris
