Bryston 4B SST clone
They are 49.9. I have uploaded a photo just in case you can spot anything.
Thanks for all of your input.
So I followed the wiring in the attached document.
C6 is 68p as per schematic, its rated at 1000v which is probably why its large. It is the feedback cap.
All devices have insulators between them and the heatsink, I also checked for shorts between the heatsink and the devices. The heatsink is grounded.
Transformer specs
The amplifier is working perfectly!
Just need to order the transformer and could do with some help.
I will be ordering a custom audio transformer from Toroidy.
I will be running it at around 65v so I thought that the following would work?
4 x 50v at 250Va
1 x 18v at 15Va
Just want to check before ordering.
That's 4 x 50Vac windings on a 250VA toroid? I'd say the rating is a bit on the low side, 500VA would be a bit more like it. You probably don't want more than 70-75Vdc after rectification and smoothing so bear in mind that although the UK ac mains is nominally 230V its actually 240V. I'd either get the primary wound for 240V or get 45Vac secondaries
