Breaking my head over AC+DC heater reference
This is Ketje´s idea - with a choke and an AC path for the more power hungry tubes.
Not sure about the snubber and the choke´s value, though.
Of course there is a reference from the DC heaters to the AC heaters. You are not free to connect/reference them in the way you ususally would.
The LM317 is not really needed, the DC voltage could just as well be adjusted with a choke of exactly the needed impedance, if line and load regulation is not what you want.
Grommeteer, normally the choke is placed after the diode bridge, not before.
If a rectified and regulated DC is used for some of the valves using a bridge rectified supply, then it may be better to make the positive regulated output as the "0V", and make the 0V a negative regulated voltage terminal, as the new '0V' will provide a better 'balance' of the AC heater voltage around 0V. However, the AC heater voltage is only referenced to the 0V for a very short portion of each mains period when the diodes are conducting - otherwise it is floating, which is by far the majority of time.
Also probably worthwhile putting a capacitor across the AC heater winding, so that leakage inductance induced noise doesn't find the output valve heaters as the easiest path to take.
Personally I'd go for a second tube / valve of the same type acting as a dummy for the 6.3V filament. Reason being is that the filament resistance changes as it gets hotter until it reaches stable. That can change the balance of the humdinger. Although, I do like the balanced approach of the resistor on either side of the 6.3 V tube.
