Rhysh,
I am already on the wiki for four boards.
I would be interested in the BOM parts. If they do NOT include the chassis. I have enough aluminum here to build a small jet.
Anyone know of a way to incorporate a servo setup into this build? It could be a rather nice addition. There seems to be enough space if mounted slightly above the board.
Thanks Tad
Thanks Tad
Yes, the kits will be to populate boards only. I will leave it up to you to you to source the chassis and PS.
a couple of empty pads for this sort of optional circuits adds nothing to the cost and adds nothing to the area of the PCB.tryonziess said:Anyone know of a way to incorporate a servo setup into this build? It could be a rather nice addition. There seems to be enough space if mounted slightly above the board.
Adding multiple pin pitches for all the capacitors allow much more flexibility in cap choice.
Adding pads for test points is also very useful.
Hi Rhysh:
Do you still have the boards? Can i have 4 please ? Please email me your paypal account and the total amount thanks
huy5005 said:Hi Rhysh:
Do you still have the boards? Can i have 4 please ? thanks
Yes, there is still room for you to fit on the group buy. Please check the wiki for payment details (accepting now), and also state if you would be intrested in a kit.
Everything is on the wiki.
R
Would like to get all payments in from current participants, in the next couple of days. Group buy will still be open to new participants until monday.
R
R
rhysh, what heatsinks and caps(40-60K uF) are you going to use, I was planning on using hifi200 as well for cases.. I just sent payment.
Nick
Nick
HaLo6 said:rhysh, what heatsinks and caps(40-60K uF) are you going to use, I was planning on using hifi200 as well for cases.. I just sent payment.
Nick
I am using the 'Pesante Dissipante' 3u 300m case with inbuilt heatsinks per monoblock. I am using 68,000uf computer grade caps that i happen to have to hand. I will use 2 of these per mononlock.
$ Confirmed.
HaLo6 said:Is there a certain capacitance for the power supply caps that is suggested? Max-Min?
I am using 2 x 68,000uF per monoblock. That is one cap per rail. I belive alex88 uses 2 x 47,000uF caps per rail. More then 68,000uF is unnecessary, but i belive it will sound diffrent depending how you setup the power supply.
rhysh said:
I am using 2 x 68,000uF per monoblock. That is one cap per rail. I believe alex88 uses 2 x 47,000uF caps per rail. More then 68,000uF is unnecessary, but i belive it will sound different depending how you setup the power supply.
Anyone tried a bank of smaller caps to achieve this capacitance? I understand banks of smaller caps can improve the sound of the midrange and treble.
I would like to try a pair of Avondale Audio
CAP6 modules with my BPA300.
Any thoughts?
- Group Buys
- BPA300 Round 2
