I want to resurrect a project I started many many years ago and back burnered. I have these major components: 272fx, 1650r, and 5881s. My original plan was a guitar amp with 4 - 5881 power amp section. I built a mosfet dual adjustable power supply so I could play with different levels designing the preamp/poweramp, roughly 80v-150v and 250-390. I didn't get much further than that.
Doing some searching, it appears that 272fx is for low wattage amps and I think I will starve it trying to power up output tubes.
My question is, could I build a lower power project using the parts I have resulting in a 2 5881 Push Pull PA or would I have to downsize the output transformer? My initial thought is the 1650r would just be overkill but still functional.
You're right according to Hammond, so go ahead with what you have.
