Can I use 2X55V trfos for 60V rail voltages or should I go down to 50V rails. Can't seem to find 2x60V trafos or small 2X30V trafos.
protos,
Plitron has an 80 VA, 60V + 60V toroidal transformer; I just ordered one for building a BoSoZ. Their part number for that part is 037052201.
Ren
Ren
protos
The 2 x 55V transformer will work perfectly.
If you are going to throw it away, I would like
to let you know my address. 🙂
Hello,
The 55 V trafo can be used.
The BOSOZ will work well even with lover voltage.
If you sometimes can't find the transformer with the desired
voltage, than try to ask around the shops if they can custom made it for you.
Best regards,
Kristijan Kljucaric
http://web.vip.hr/pcb-design.vip
Best regards,
Kristijan Kljucaric
I used one 80VA, 55+55V transformer from Avel Lindberg for my BOSOZ. It works pretty good and the rail voltage is 60V.
Wallace
Wallace
With 55V you still have around (-)75V on the drains of mosfets in psu so you have 10-15V reserve, that should be enough..
Another PSU question.
Here in South Africa our 220v mains are actually 235v. Now instead of getting 80v D.C. after my rectifier , I get 90v.
Questions:
1. Is this a big problem?
2. If so, can I just add another zener to the pack, each side?
3. Must I use 7 x 9.1v zeners, or can I use for instance 5 x 12v zeners?
4. On my Aleph30, still waiting for transformer, I must have 25v on rails, but will now have 30v, any problem with this?
Thanx to all.
Questions:
Thanx to all.
- Bosoz psu question
