the older bose 901 each driver running at 7/8 ohm right(like series 1 and 2),then after series III thier each driver only running at 1ohm?and i have an old pioneer amplifier tunning at 8ohm,so when i buy the driver i use a old and a new driver in my speaker box,it can also running at 8 ohm?
You say you have 2 speaker drivers:the older bose 901 each driver running at 7/8 ohm right(like series 1 and 2),then after series III thier each driver only running at 1ohm?and i have an old pioneer amplifier tunning at 8ohm,so when i buy the driver i use a old and a new driver in my speaker box,it can also running at 8 ohm?
Speaker A: 1Ω + Speaker B: 8Ω.
Total Impedance in Parallel - 0.9Ω/in Series - 9Ω.
Speaker Impedance
You can run the 8/9Ω speaker (series) connected to the 8Ω amp, yes, if that's your question. 🙂
Also look at differences in power from the simulation.
no i say is if i have a bos that have 3 speaker 1=1ohm,1=4ohm(tweeter),1=8ohm speaker in the same box can it fit my 8ohm or above amplifier?You say you have 2 speaker drivers:
Speaker Impedance
