ThSpeakerDude88 said:Any curcuits that could use this?
White noise generator.
These parts are obsolete and it may turn out to be waste of time to build up something from these. For also very low price you will get tl07x or NE5532 op-amps, which are way better. Modern power trasistors will be probably something like 2$.
No need to use your old dirt whereas silicon costs nothing nowadays, main expense is transformer, heatsink and PCB.
nice, I think that will work. If I set it up in multisim and test it will it give me close to accurate results? By the way... multisim looks very close to p-spice.. I downlaoded p-spice one time but I couldn't get it to work.
what voltage do the diodes need to be ( or are they not zeners?)
Yes, the output is from the top transistors emitter/bottom transistors collector. An output capacitor is not required. The reason is that it has a plus/minus supply and the op-amp compensates through the feedback loop to keep the output the same as the input. When the input is 0 volts, the output is 0 volts with respect to ground. So the top transistors Vce will be 15, as well as the bottom transistors when the input is 0 volts. The output from the op-amp will have a dc offset of 2Vbe or ~1.2-1.4 volts. The dc offset of the power amp over all will be 0 volts.
Oh. This works fine in the simulator. It takes a 1V input and turns it into a 13V output. When I built it in the shop, I added a 10 ohm resistor and 100nF capacitor in series from the output to ground and a 100pF capacitor from the output of the op-amp to the inverting input of the op-amp. This kept it from oscillating at all. It sounded very good. I used Tip 125 darlingtons and LM741. It still sounded good with this stuff. The cymbals sounded like ****, but I had 180pF from the output of the op-amp to the inverting input, which limited the high-end response. I didn't have anything else. The bass sounded very good though. Better then my 50W/channel amp that I had built out of LM12CL power op-amps.
latala said:build a texan
this was a very simple amplifier that used a 741/748 opamp and 2 small npn bc212 1 x pnp bc212 a tp32 and a tp 32
results were very good about 15-20 watts many thousands were made i will try to get a schematic on when i get my scanner to work
Hi Latala,
No need for scanning, here it is: (the first schema)
http://skory.gylcomp.hu/25wamp/25wamp.html
The text is in hungarian...
On the margin I really agree with Darkferniz!
Best R.
well shoot... I don't have a dual supply. I have 7812 and 7912 regulators, but that would only give me +/- 12v... I do have a 32v power supply, any way to adapt one of these to that?
also, Is there any way to do this with only 1 output transistor? what about using a power amp IC to drive the transistor.. I have a couple 25 watt ones and some 15 watt ones, as well as one TDA2050 which will do about 30 on the power supply I have. I saw somewhere on ST's website one time they had a 60 watt driver, it was just a 14 pin ic and all you needed to add was your choice of power transistors.
How about a simple op-amp driving a push pull quasi output stage. Single PS would most probably need a DC block cap on the output. I think i've seen designs like this in an older RCA app note. Up to 12-20Watts output but could be upgraded with more parts for higher power.
Signetics used to make a high voltage audio driver IC for full compl output stage NE540 I think.
I don't see why not. If used in place of a simple op amp may reduce the need for some components but you still may need a pnp driver anyway for quasi outputs. See if you can locate any designs using op-amps and take a closer look. RCA transistor manual circa 1974 is what I have. But just going on the 2 brain cells I have right now.
Maybe this is simple enough
http://www.geocities.com/leobodnar/audio_amplifiers.html
- Bored...2n3055e amp?
