Bob Cordell Interview: BJT vs. MOSFET
Re: S-K Filter Simulation and Monte Carlo
analog_guy said:
I have seen the same behavior in simulations and believe it has to do with the phenomena occurring at the onset of oscillation. In order for oscillation to start the simulator may need to provide a "kick" to push the system under consideration off a local minimum. One simple workaround is to intentionally introduce a small amount of random noise or a noise pulse.
We have also seen the converse of this problem, where an amplifier will apear stable under quiescent conditions but will oscillate when presented with certain input signal conditions.
Thanks, I had not thought of that, and I'll try it.
WTR to the converse case, at least that corresponds to a real
behaviour. Oscillation will often break out in only a portion
of the operating swing.
Hmmm... I gave it a good kick, and it still doesn't oscillate.
Hi Tim_x,Nelson
The 34db difference does show the need for balanced circuits to be intentionally imbalanced in simulation.
Alternatively, you should match the transistors in practice! I've pointed out in previous threads that I match transistors wherever they are needed. This means driver pairs, output (parallel) pairs and diff input pairs, current mirrors, etc. Matching small signal devices is almost as easy as falling off a log, since several purchased at once will almost certainly have the same date code, and maybe from the same wafer (if you ar lucky) or at least the same lot run.
I have in the past used a series of models for individual devices, but with suffixes, so that they represent different gain spreads (and when plotted will give a Gaussian distribution). But it's hard work as model parameters are in some cases correlated, and each variation has to be determined by some knowledge about what causes the variations.
And of course, one reason lots of feedback is used is to minimise the spreads in transistor/passive component variation.
I've also used the kickstart method to simulate a crystal oscillator. Ever tried? the huge equivalent inductance and small capacitance really takes some momentum to get going (i.e. it never starts without being kicked). I just used a voltage source with a single pulse (in this case 500V/1uS).
Nelson's point about models never being right is correct in that some effects aren't modelled well in the older generations of simulation. I can believe that single precision simulators got things badly wrong, but 64 bit precision, which is now standard, should be good for quite a low % distortion. I agree though that some effects such as quasi-saturation resistance, which the gummel-poon/Level 3 type models don't have, and breakdown effects (which some models don't have) can make simulations optimistic. Thermal effects are only just being thought about, and no doubt soon we can plug in our thermal insulators, heatsinks and watch for temperature effects (it might be quicker to build the amp and measure). But if you want your 1 ppm amplifier, I still think that the simulator needs to say it is possible with the tools available. Then you check.
cheers
John
Interestingly, some of the best results I've seen have not been
cases of matching per se but from swapping parts in and
out and tweaking current and resistance values around each
one. If you do it with a distortion analyzer, you can often find the
more narrow "sweeter spot" than with matching alone.
Nelson Pass said:
If you do it with a distortion analyzer, you can often find the more narrow "sweeter spot" than with matching alone.
Perzackly. The distortion analyser is already looking at the second order effect (rather than the first order). Useful for those of us who can measure distortion, but perhaps less useful for everyone else. Mind you, I've often found that such distortion minima (in valves, not semiconductors) tend merely to minimise H2, and possibly increase higher harmonics, making them less useful. There's just no free lunch.
I'll go away now and leave you to semiconductors...
:rofl:
Hi Nelson,
I used to just match on beta, but I recently built a "diff pair" tester. It's just a current source that you plug in your hopefuls and look for a collector (or drain) current balance. It mimics a diff pair without any feedback. That gives me very tight matches.
-Chris
Hi Nelson,
Well, if you test in-circuit, you can select for whatever makes you
There's the rub. This little circuit comes with sockets. My other ones don't.
I find it interesting to experiment to see what make a real difference. I'm sure you do the same on the bench. This does as you do, but with less bother and no soldering iron. 😉
-Chris
Bob Cordell said:
BTW, have you used the ON ThermalTrak devices yet? Even as a transistor apart from the thermal tracking diode, they look better overall than the Sanken RETs. Don't go by what it says in the spec sheet table; look at the actual typical beta vs IC curves and the ft vs IC curves.
High-current beta falloff appears about the same, but Beta appears a tad flatter at lower currents.
Ft at 1 amp of the Sanken 2SA1295 is typically 30 MHz, while the NJL1302D is at about 41 MHz. The typical ft peak of the 1295 is 38 MHz at 4A, while that for the 1302 is 45 MHz at 4A. They are about the same at 6A, then beyond that the 1295 is better. At a low typical idle bias current of 100 mA, the 1295 is only at 12 MHz, while the 1302 is at 17 MHz. As always, there are tradeoffs.
Cob at 10V is about the same for both devices, at about 500 pF.
SOA at 10 ms, 100V appears comparable at about 3.5A.
Also, they have the friendlier TO-264 package (BTW, is it hard to get the insulators for those Sanken two-screw packages?).
What do you think of these ThermalTrak devices?
Cheers
Bob
Hi John,
I'm still interested in learning your experience and opinion on the OnSemi ThermalTrak transistors.
Bob
john curl said:
Are you referring to me, Bob? You should contact Charles Hansen. He is the going expert on ON semi at the moment. I don't need these devices in my current designs at this time, but for a smaller amp, they might be perfect. Why? Quiz on Friday.
Hi John,
Yes, I was referring to you. Now I'm really curious with regard to your quiz question about why these devices might be perfect in [only] a smaller amplifier.
I'm guessing that you are referring to the TO-264 package for the OnSemi parts as opposed to the double-screw package of the Sanken parts. I'm guessing that you like the larger metal surface of the latter to obtain a smaller theta CS. Am I right?
If I'm right, that would seem to make sense in amp designs where the choice of the number of paralleled output pairs was dominated by average junction temperature considerations as opposed to concerns about short-term SOA or high-current beta or ft drop-off. Am I right, or have I missed something.
Thanks,
Bob
