hitsware said:>IF you are in class A mode exclusively, THEN there is no optimum >value of voltage drop across the emitter resistor.
Shouldn't it be the same drop as across the load?
No, John is talking about complementary push-pull operation,
where relatively small Source/Emitter resistances are used to
stabilize the bias current. In this case, the voltage drop across
the resistors is small.
Hi hitsware,
It doesn't work like that. You would increase the losses (heat) dramatically.
The goal of most amplifiers is to make the output impedance of the amplifier as low as reasonably possible with respect to the load. What you are thinking about is power transfer for AC generators and the like. RF transmitters also work on this principle.
Tube amplifiers use load matching for different reasons and it is still not equal to the load. The damping factor would be one, or unity, in that case. Not very useful.
-Chris
-Chris
Hi hitsware,
-Chris
Nope. You defined it as .......Depending on your ' load ' .....
There was some stuff about emitter resistors in there too. That would create an undetermined source impedance. Your damping in that case would be less than unity.equal that of the load.
(for maximum power transfer)
-Chris
Fellow designers, you are confusing the issue. These are elementary questions.
The emitter resistor is added to increase thermal stablility. The larger the resistor, the more thermal stability. However, the open loop damping factor might be effected significantly, if the value is 1 ohm or so. My original amp with 1 ohm resistors had a damping factor of 30, BECAUSE it had about 40 dB of negative feedback. More than enough for my purposes at the time.
However, there IS an optimum value of emitter resistor for optimum transistion between class A and class B operation in a class A-B power push-pull bipolar transistor amp. Unfortunately, it is usually a VERY LOW value, such as .05-.22 ohms, and this MAY not be enough resistance to give adequate thermal stability without active thermal tracking.
What I meant was if you say had a 8 Ohm speaker that worked well with say a 8 Ohm series resistance. But I know that is not the convention so is inappropos for this discussion.anatech said:Hi hitsware,
-Chris
Hi John,
Thanks. I was going to get there once hitsware replied. The question of output impedance of an amplifier vs the emitter resistance completely changes once you wrap it up in a feedback loop.
The entire issue of thermal stability vs emitter resistance is also dependant on the thermal resistance of the heat sink (in case) as well. I like to see a slightly negative temperature co-efficient for bias vs temperature.
Hi hitsware,
-Chris
Hi hitsware,
I would expect that speaker to have a very flat impedance curve for one. The damping factor is one, or unity in that case. You are correct, this is almost never seen.What I meant was if you say had a 8 Ohm speaker that worked well with say a 8 Ohm series resistance.
-Chris
Anatech, IF you want a thermal tracking circuit with a slightly negative temperature coefficient, you might try my complementary transistor tracking diode method. I have been using it since 1970 or so, and it tends to track pretty well and go slightly negative when pushed. For some reason, it seems to be slightly better than a single transistor tracking circuit. Perhaps, it has just been my good luck, but it is worth a try.
john curl said:Fellow designers, you are confusing the issue. These are elementary questions.
John,
You said in two (OK, three) sentences what Self needs two chapters for. Thanks!
Jan Didden
john curl said:Anatech, IF you want a thermal tracking circuit with a slightly negative temperature coefficient, you might try my complementary transistor tracking diode method. I have been using it since 1970 or so, and it tends to track pretty well and go slightly negative when pushed. For some reason, it seems to be slightly better than a single transistor tracking circuit. Perhaps, it has just been my good luck, but it is worth a try.
Wher can we see the schematic?
Hi John,
http://marklev.com/ does not seem to exist any more. http://www.marklev.com/ does not work either. Still hunting .....
-Chris
-Chris
say cheese: www.tcaas.btinternet.co.uk/jc-3.gif
(placing the Vas of the Halo JC-1 next to the one of the JC-3 is also interesting)
john curl said:Might be a good idea to try.
Why John, I *am* surprised!
Error correction is just gain in the feedback loop.
So if you think feedback is good, I say use as much as possible. Use error correction, use complementary feedback pairs, use nested feedback loops, do it all! You could even do one of the tricks used by Jadis -- add *positive* feedback to increase the gain of the circuit so that you can get more *negative* feedback out of the circuit.
But if feedback is not good, then don't use any....
- Bob Cordell Interview: BJT vs. MOSFET
