Bob Brines, Mark Audio T7-A7
I agree this board sounds very interesting. It would be good to have a 12dB/octave LR board too.
With bass assistance they might be too good!
Indeed.
dave
Delivery for the XO will be in 39 days so I've got time to build the subs.
I looked around and found SB ACOUSTICS 8” WOOFERs for $AU110.ea.
Is this driver suitable for smallish boxes?
I'm not trying to reproduce explosions and earthquakes only fill out the bottom.
Here are the specs.
Order Code SB23NRXS45-8
Type Papyrus
Power 60Wrms
Impedance 8Ω Nom. (Re 5.6Ω)
Sens. 89dB
Re 5.6Ω
Qms 5.4
Qes 0.41
Qts 0.38
Vas 94.0L
Sd 216cm²
Fs 27Hz
Zn 8Ω
Le 0.60mH
Sb23nrxs45 8, Sb Acoustics 8? Woofer, Sb Acoustics | Wagner Online Store
I plugged the numbers into online sub-woofer calculators and got very different results. I don't know enough to use them.
I'm happy to buy plans from someone who has done this before.
Thanks, Mack
Btw, the Dayton Classic woofers are quite cheap (6.5" units are around 1/2 price of the reference series), but at the cost of higher distortion. They have been termed as "euphonic" by a designer for mid-bass applications... however this is a FAST case and XO will be lower... so
Guys,
If OP is crossing really low (100-200 Hz) will it matter a lot?
I know X likes low distortion products 🙂
Guys,
For 8in Classic it has only 4.5mm xmax vs 7mm. That is something you need lots of for a FAST woofer. But otherwise the Qts, Qms, etc are similar. Classics are quite nice for $25.
Today was slow at work as you can see by my many posts.
It was also an expensive day. I ordered the XO and just ordered 2 Dayton Audio RS225-8 8" Reference Woofers.
Thank to everyone for their suggestions and input. I'm really excited about adding subs to my B.Brines M.Audio 7.3 MLTLs.
Next is to find out about ported/sealed and size compromises.
Yay! Mack
Tilroh,
Glad you were able to get the Daytons in Australia. If you make your own analog op amp Linkwitz transform circuit, you could add it to signal path of woofers after XO and before amp. Otherwise you will need vented. My calcs show a 23 liter to 24 liter cabinet tuned to 38 Hz works well. You get decent group delay still. Make sure you have ability to physically move your A7 cabinet back and forth relative to bass cabinet for time alignment. My estimates say you may need to set the A7 about 3inches behind the RS225.
