Blown DS18 PRO-KA5000.1D
This is the gates of two banks of PS FETs with the probe grounded to the source leg. All of the gates are identical.
The probe shows a clean square wave on the scope test terminal in both 1x and 10x mode. The waveforms on the PS FETs gates and the driver IC outputs are much more square when the probe is 1x at 50v but I don't know if that is not using the scope properly. Scopeshots posted.
Not in the US, located in Trinidad and Tobago, West Indies.
Computer and Power Supply are both 3pin plugs with grounding pin.
Are the probes the same from this isolated OWON, and the Hantek and SainSmart USB scopes I had before? One of the OWON probes was not able to calibrate to a completely flat square wave on the 5v test tab.
I used an old probe to scope the PS FETs but cannot do the same to the outputs as the amp goes into protection when the probes are connected Gate to Source on both high and low side outputs at the same time. Using one probe, the low side shows fine on one Scope trace, but the high side affects both Scope traces.
I don't think there is a problem in the Power Supply of this amp but I suspect there may be an issue with the output drive. The readings on the output drivers (C2814) legs from the gate resistors of the high side are suspicious as compared to those of the low side.
What output IC is used on this driver board?
I think it uses standard probes but the BNC connector is insulated (for safety) on the OWON.
You only have one isolated ground. You can't use two different ground points. Use only one probe at a time.
From what I have, the ZNCM_HP uses 21844s. This board likely does as well.
Check the high-side by connecting the ground clip to the source leg and the probe tip to the gate. Do NOT let the clip short to the high-side drain.
Are the outputs in the amp?
Gate resistors were replaced with same value as original, 22ohms as well as replacing all 8 IRFP260M. I will reinstall the board and test it but I remember the output inductor was the hottest component on the board, but the whole output side of the amp heatsink was hot. Should I try a different value gate resistor for the amp to run cooler?
All semiconductors were purchased from Mouser Electronics except the gate resistors, they were purchased locally but read within tolerance and haven't had any problems with parts from that supplier.
EDIT: Actually, the gate resistors for the outputs were not changed as they were undamaged and read within tolerance. Should I change the gate resistors? I changed all the outputs.
Reassembled the amp and had it running for12-15 minutes and the is about 7-second-touch hot to where I have to let go. I can put my finger on the output clamps without any discomfort as they are not really hot, just a little warm but the chassis/heatsink on that side of the amp is pretty warm. The waveform of the high side outputs is not as clean as the low side. The high side is where the shorted output was...
Probe 2 (yellow) has the cursor and trace aligned to each other, but Probe 1 has the trace a little higher than the cursor and I don't know how to align them. I used Probe 2 to scope the high side drive before and after the gate resistor at 5V/5us.
I would have to research how to align the trace and cursor for Probe1.
There are 2 A1715 and 2 C2814 for each bank of four outputs in between the driver IC and the outputs.
