Blew something in a Chinese JLH1969 circuit. How to diagnose problem?
Sorry -- another basic question...
I was adjusting a pair of these for 24V/1.2A when I heard a tiny "tick" somewhere. After the "tick" I've now got no voltage at the "1/2 voltage (KT1 adjusted)" transistor.
I assume I blew something. Nothing visually changed anywhere (no scorching or blown caps). Replacing both trimpots on one of the boards didn't solve the problem.
Any ideas of what happened? Can I test items installed in the circuit with a multimeter? If I can, any suggestions what to check?
Reactions: STOXX
Did these ever work prior to the failure? Are there notes about presetting the pots?
Probably a transistor, try in-circuit testing first. For each transistor, use the DVM diode test in both polarities.
Check BE, BC, and CE, for short, open, and normal forward reading.
Reactions: STOXX
This is not the "real" circuit, and it may have used or fake parts. But give it a try.
Inputs should have shorting plugs inserted, and the outputs should have 10 ohm 20W resistor loads.
Don't connect to speakers unless/until these boards are well tested and burned in.
No way to know, but always do this with any amplifier to avoid unnecessary surprises.
It's also important to have the pots at a suitable initial position before applying power, preferably with a fused Variac.
Lacking that, an incandescent bulb (of suitable wattage) in series with the AC line can limit the current.
Reactions: STOXX
VR2 is the weakest link in the schematic considering all things Chinese.
On my builds, I use a 1 Watt Bourns in that position. Very important flaw on those China builds.
I have had amazing results with the offshore JLH1969 boards but I never use their parts.
Thanks for your replies, Stoxx, I appreciate all if the information. I'm afraid I'm a rather pathetic beginner -- I can follow assembly instructions, but my electronics knowledge is minimal.
I'm still trying to figure out how to remove soldered-in items. I've tried various kinds of solder suckers and solder wicks - the process drives me nuts!
Reactions: STOXX
You need a solder pump, it takes a lot of practice and dangerous, you just heat it and place the pump there, after it liquefied you release the trigger, you can dry a joint that way and release the component fairly easy
The click is the trimpot going full range, you reach the point at wich it is fully one side or the other,
Please place a load whenever adjusting anything, it prevents a lot of problems,
My version of the jlh is way advanc3d and can deliver 15 amps in a short then the fuse would blow
I had tube amp destroy 1 watts dummy resistors, better this tan a winding, same, better destroy a resistor than many transistors
